I am using imx6ull kernel 4.1.15. It is connected to an old PC by UART, and noise causes an infinite 0xff Rx problem. At this time, even if the cable is removed, this phenomenon continues. Is it a chip problem? I also saw a post that says that enabling the auto baud rate detection function will solve it, but we have to fix the baud rate. Can you provide a perfect solution?
Thanks.
Sungkyun Ko
已解决! 转到解答。
Hi~
It was confirmed that it returned to normal after SW Reset. But is it possible to detect whether a 0xff storm has occurred with S/W? For reference, in my case, frame error is not set when 0xff storm occurs.
Thanks.
Sungkyun Ko
Hi Sungkyun
one can try with new kernels as they have uart driver improvements, also one can
check hardware: use short shielded cable, pay attention to grounding board and PC,
try to ground them in one point.
