I.MX6UL SPI DMA driver example
4,630 次查看
hansonhe
Dear,
Do you have the I.MX 6UL bare-OS SPI DMA driver example or reference code? Thanks.
8 回复数
3,731 次查看
Hi Hanson
I am afraid such i.MX6UL bare metal example is not available,
however one can reuse attached i.MX6 sdk example, refer to
Chapter 29 Configuring the SDMA Driver pdf document.
One can obtain full sdk creating service request.
3,731 次查看
hansonhe
We find your attached file which missing below file,
#include "sdk.h"
#include "profile/profile.h"
#include "core/interrupt.h"
#include "registers/regssdmaarm.h"
#include "sdma_event.h"
另外查看文件sdma_script_info.c:
#if defined(CHIP_MX53)
#include "sdma_script_code_mx53.h"
#elif defined (CHIP_MX6DQ)
#include "sdma_script_code_mx6dq.h"
#elif defined (CHIP_MX6SDL) || defined (CHIP_MX6SL)
#include "sdma_script_code_mx6sdl.h"
#endif
We do not see the file which use by CHIP_MX6UL, could you help check which header file is suitable for IMX6UL?
3,731 次查看
SDK does not support i.MX6UL and files were given just as example for
developing specific examples for i.MX6UL. Note, NXP has Professional Services
for helping to port software
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
3,731 次查看
hansonhe
Dear Igor,
How about the professional service flow? Whether need customer to apply service by themselves directly?
Does it need external cost for them? Thanks.
3,731 次查看
Hi Hanson
please fill form request on that web page,
unfortunately I am not aware details, sorry.
3,731 次查看
hansonhe
Dear Igor,
SPI or SDMA will have completion interrupt after all the content, whether it have interrupt for the start or the middle of the data transmission in I.MX6UL ? Thanks.
3,731 次查看
Hi Hanson
I believe it will raise interrupt after completion transfer
3,731 次查看
hansonhe
dear, i have login problem for Service request, could you help sent it to mail: [email protected], Thanks.
