Hi igor,
How can I set the "MX8M_DDR3L_RPA_v6.xlsx" file ,I tried so many times,but always fail. The follow pitcure1(16bit data width,two CS)and pitcure3(32bit data width,two CS) are my configuration, picture2 and picture4 are the DDR TOOL calibration resualt.
Finally, I found when configure one CS signal ,that is to say enable one ddr3 only, the calibration get passed. The following is screenshot.
I want to know how to configure the parameters to make two ddr3 chips work.Could you give me the direction?
Thank you for help.
Best regards.
