How to use nxp pin config tool for pin multiplexing in imx8mplus in yocto project?
1,660 次查看
vivek338
Hi !
I need help on pin multiplexing using config tool and integrate in yocto project. I am working imx8mplus development board.
Please help!
4 回复数
1,646 次查看
florian_arndt
Senior Contributor I
Hello vivek,
so what is your specific question?
1,639 次查看
vivek338
Hi !
I want to change pin functionality using config tool and add that dts to yocto project.
1,606 次查看
Chavira
Hi @vivek338 !
Thank you for contacting NXP Support!
As @florian_arndt mentioned, Config Tools helps to generate a customized device tree according to your necessities.
To compile your customized device tree you can follow the next instructions.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-use-Devshell-to-compile-device-tr...
Best Regards!
Chavira
1,633 次查看
florian_arndt
Hello @vivek338,
just select the pin multiplexing you want to have via the "Pins Tool" and then export it via the menu. You can find some pictures in the appendix.
1) Configure your multiplexing by clicking on the specific pins in the CPU ball grid.
2) Or configure your multiplexing via interface selection in the left column.
3) Then export it.
4) Choose what you want to export.
5) Select your target directory.
I hope this helps.
