How to use MFG Tool?
2,794 次查看
joowonkim
Hi everyone.
I download MFG Tool.
I connect USB to UART, USB OTG and power.
But MFG Tool isn't read my board and SDcard.
How to build ubuntu image on board using MFG Tool?
Thank you to read.
p.s) I using i.MX6Q SabreSD.
标签 (3)
1,794 次查看
igorpadykov
Hi JooWon
please read document below describing basic steps
http://2012ftf.ccidnet.com/pdf/0066.pdf
Below you will find Freescale BSPs
i.MX6Q|i.MX 6Quad Processors|Quad Core|Freescale
Operating System Software-Board Support Packages (34)
If MFG Tool can not connect to board - for this problem I would
suggest to create separate thread, since this is hardware problem and may
be answered in different thread. As starting point suggest to run DDR tests
https://community.freescale.com/docs/DOC-96412
