How to update 1G DDR3 to 2G DDR3 on i.MX6QSabresd board
4,333件の閲覧回数
浩卢
hi:
How to update 1G DDR3 to 2G DDR3 on i.MX6QSabresd board.What should I do with uboot and kernel?
Now I am using  the vesion L3.0.35  4.0.0.
ラベル(2)
3,770件の閲覧回数
Hi 浩卢
in uboot/../configs/mx6q_sabresd.h change ddr size parameter
PHYS_SDRAM_1_SIZE
change dcd header with new ddr settings obtained from DDR test
uboot/../mx6q_sabresd/flash_header.S
https://community.freescale.com/docs/DOC-96412
3 返答(返信)
3,771件の閲覧回数
Hi 浩卢
PHYS_SDRAM_1_SIZE
3,770件の閲覧回数
浩卢
Hi igorpadykov
Can you give me some suggestions about this problem ?How to update 1G DDR3 to 2G DDR3 on i.MX6QSabresd board 3.14.52
3,770件の閲覧回数
浩卢
hi igorpadykov
Thank you very much.I got it with your solution.
