How to transfer files from remote host to target
3,145 次查看
Swamy
I am using IMX53 Sabre Tablet, 11.05 code release.
I have a debug port where I have COM Port and Ethernet connected to the target. Telnet to the target is also working.
Now I would like to copy the file which is present in my PC to the target, Please tell me how to do this?
Swamy
标记 (1)
5 回复数
3,000 次查看
KrishnaPavan
https://linuxlink.timesys.com/docs/gsg/i.MX53START
This gives a step by step detail. Give it a try!
Regards  Krishna Pavan
3,000 次查看
Swamy
Thanks for all the suggestion,
Please let me know how do we make use of tftp. and how to make remote folder mount?
Swamy
3,000 次查看
JoshuaParrish
If your using windows,
I would recommend the combination of winscp and putty.
running linux, I would recommend scp (As Mahesh suggested) and the ssh commands.
However Micheal's suggestion of tftp is already loaded on (I believe) so it's a good option too.
You could also do a remote folder mount.
3,000 次查看
MaheshMahadevan
scp is a good application to try transferring files back & forth to the target over the network.
3,000 次查看
myke_predko
Senior Contributor III
Hi Swamy,
Have you looked at "TFTP" (http://www.linuxhomenetworking.com/wiki/index.php/Quick_HOWTO_:_Ch16_:_Telnet,_TFTP,_and_xinetd#TFTP)?
Quite fast and reliable.
myke
