How to stream video from iMX8M plus using Gstreamer and RTSP
1,449件の閲覧回数
Vijay_hegde
I am trying to stream video from my i.MX8M plus board using Gstreamer and RTSP (mediamtx tool).
Trying with gst-launch-1.0 commad (but not has x264enc support) .
Is it only possible using gst-variable-rtsp-server command?
Or can you help me with setting up the things.
i.MX8M
5 返答(返信)
1,318件の閲覧回数
Vijay_hegde
hey can you help me with the system configuration to build imx-image-full. Currently I am doing it on 64 GB RAM and 2TB storage. But process gets killed like system crash.
1,303件の閲覧回数
joanxie
pls create a new thread for this new issue, and attach detailed logfile you get(what kind of crash you get), building issue or booting up issue? it's better if you can give us the detailed steps, we can double check it, it's hard to help you if you only said system crash
1,398件の閲覧回数
Vijay_hegde
Thank you.
To use OpenCV and ML do I need imx-full-image or I can build it no top of other image.
1,392件の閲覧回数
joanxie
yes, if you want to use ML, you need build full images
1,416件の閲覧回数
joanxie
pls refer to the link as below, the command was tested official before in this link
https://community.nxp.com/t5/i-MX-Processors/Unable-to-get-RSTP-streaming-working-imx8mp/td-p/205146...
