How to stream video from iMX8M plus using Gstreamer and RTSP
1,609 次查看
Vijay_hegde
I am trying to stream video from my i.MX8M plus board using Gstreamer and RTSP (mediamtx tool).
Trying with gst-launch-1.0 commad (but not has x264enc support) .
Is it only possible using gst-variable-rtsp-server command?
Or can you help me with setting up the things.
i.MX8M
5 回复数
1,478 次查看
Vijay_hegde
hey can you help me with the system configuration to build imx-image-full. Currently I am doing it on 64 GB RAM and 2TB storage. But process gets killed like system crash.
1,463 次查看
joanxie
pls create a new thread for this new issue, and attach detailed logfile you get(what kind of crash you get), building issue or booting up issue? it's better if you can give us the detailed steps, we can double check it, it's hard to help you if you only said system crash
1,558 次查看
Vijay_hegde
Thank you.
To use OpenCV and ML do I need imx-full-image or I can build it no top of other image.
1,552 次查看
joanxie
yes, if you want to use ML, you need build full images
1,576 次查看
joanxie
pls refer to the link as below, the command was tested official before in this link
https://community.nxp.com/t5/i-MX-Processors/Unable-to-get-RSTP-streaming-working-imx8mp/td-p/205146...
