How to show a frame rate of h.264 decoder output with gstreamer?
2,274件の閲覧回数
t-iishii
I hope to know a frame rate as h.264 decode result.
Can I get a result of the decoder output frame rate using gstreamer?
If no, please teach me some method to show a frame rate of h.264 decoder result.
Ishii.
ラベル(4)
4 返答(返信)
2,049件の閲覧回数
joanxie
you can find out from log file when you decoding the file, the log file would shows the time and frame number, then you can calculate it.
2,049件の閲覧回数
t-iishii
Hello Xie,
Thank you for your quick response.
As you say, that log file mean to use "GST_DEBUG" and "GST_DEBUG_FILE" option?
If so, which number for GST_DEBUG option will be output the time and frame number?
Ishii.
2,049件の閲覧回数
joanxie
you just need to play the video using unit test or gstreamer, you can find it.
2,049件の閲覧回数
t-iishii
Hello Joan,
Thank you for your response.
I was able to see it by playing the stream to the end.
Before it, I force stopped it because play time too long.
Ishii.
