How to setting up the Eclipse IDE for M4 (for IMX8MM)
3,172 次查看
shai_b
Senior Contributor II
Dear Team,
My customer has started to work with i.MX8M mini and he would like to use a multicore application with rpmsg on the side of M4.
Could you please advise how to setting up a new project in Eclipse IDE to run a proper project in the M4 on the i.MX8M-mini (using ARMGCC)?
Waiting for your kind guideline, Thanks in advance.
Shai
标记 (3)
5 回复数
3,158 次查看
romainmoura
Here is my project.
PRINTF are redirected to UART3
3,145 次查看
shai_b
Thanks a lot, I will try it out.
KR,
Shai
3,165 次查看
also may be useful:
https://gnu-mcu-eclipse.github.io/tutorials/hello-arm/
3,169 次查看
romainmoura
You can follow this document for imx7 : https://www.embeddedartists.com/wp-content/uploads/2018/06/iMX7_Working_with_Cortex-M4.pdf
I personally use MCUXpresso, I followed this document, it works well too.
3,162 次查看
shai_b
Hello @romainmoura ,
My customer has tried to follow this guide but did not manage to build properly all the SDK tree such as rpmsg and freertos roots and he get an error while compiling.
Can you please share your MCUXpresso project example, so the customer could use it as a starting point?
BTW, I am sure many users would like to use MCUXpresso IDE for IMX8MM cortex M4
Waiting for your kind responses, Many Thanks.
Shai
