How to set the fdt_file value on yocto project
ChChang
My platform is i.mx8qm-mek, and the BSP is Linux L6.1.55_2.2.0.
Currently, the generated image file uses
imx8qm-mek-rpmsg.dtb as the fdt_file for uboot.
I would like to change the default value of
fdt_file to imx8qm-mek-hdmi.dtb before Yocto generates the image, without manually setting it in uboot.
Which conf file should I modify?
Thanks!
CH
Harvey021
ChChang
Thanks for your reply ,
This problem was solved, thanks a lot!
CH
