How to modify Bootloader and kernel to support LPDDR2?
14,347 次查看
YamilGarcia
Currently I'm working with a mx6q_sabrelite platform. I would like to modify the bootloader and kernel to
support LPDDR2 instead of DDR3 already used by this platform.
Can someone give me a hint on this matter?
11,648 次查看
AnsonHuang
Hi, Yamil
     I have made LPDDR2 400MHz work on i.MX6Q ARM2 board before, please refer to below flash_header.S, search for LPDDR2, but you may need to adjust the parameter according to your LPDDR2's freq and size.
#include <config.h>
#include <asm/arch/mx6.h>
#ifdef CONFIG_FLASH_HEADER
#ifndef CONFIG_FLASH_HEADER_OFFSET
# error "Must define the offset of flash header"
#endif
#ifndef CONFIG_FLASH_PLUG_IN
/********************DCD mode***********************/
#define CPU_2_BE_32(l) \
       ((((l) & 0x000000FF) << 24) | \
  (((l) & 0x0000FF00) << 8)  | \
  (((l) & 0x00FF0000) >> 8)  | \
  (((l) & 0xFF000000) >> 24))
#define MXC_DCD_ITEM(i, addr, val)   \
dcd_node_##i:                        \
        .word CPU_2_BE_32(addr) ;     \
        .word CPU_2_BE_32(val)  ;     \
.section ".text.flasheader", "x"
  b _start
  .org CONFIG_FLASH_HEADER_OFFSET
ivt_header:       .word 0x402000D1 /* Tag=0xD1, Len=0x0020, Ver=0x40 */
app_code_jump_v:  .word _start
reserv1:          .word 0x0
dcd_ptr:          .word dcd_hdr
boot_data_ptr:  .word boot_data
self_ptr:         .word ivt_header
#ifdef CONFIG_SECURE_BOOT
app_code_csf:     .word __hab_data
#else
app_code_csf:     .word 0x0
#endif
reserv2:          .word 0x0
boot_data:        .word TEXT_BASE
image_len:        .word __hab_data_end - TEXT_BASE + CONFIG_FLASH_HEADER_OFFSET
#else
image_len:        .word _end_of_copy  - TEXT_BASE + CONFIG_FLASH_HEADER_OFFSET
#endif
plugin:           .word 0x0
#if defined CONFIG_MX6DL_DDR3
dcd_hdr:          .word 0x40E002D2 /* Tag=0xD2, Len=91*8 + 4 + 4, Ver=0x40 */
write_dcd_cmd:    .word 0x04DC02CC /* Tag=0xCC, Len=91*8 + 4, Param=0x04 */
# IOMUXC_BASE_ADDR  = 0x20e0000
# DDR IO TYPE
MXC_DCD_ITEM(1, IOMUXC_BASE_ADDR + 0x798, 0x000c0000)
MXC_DCD_ITEM(2, IOMUXC_BASE_ADDR + 0x758, 0x00000000)
# Clock
MXC_DCD_ITEM(3, IOMUXC_BASE_ADDR + 0x588, 0x00000030)
MXC_DCD_ITEM(4, IOMUXC_BASE_ADDR + 0x594, 0x00000030)
# Address
MXC_DCD_ITEM(5, IOMUXC_BASE_ADDR + 0x56c, 0x00000030)
MXC_DCD_ITEM(6, IOMUXC_BASE_ADDR + 0x578, 0x00000030)
MXC_DCD_ITEM(7, IOMUXC_BASE_ADDR + 0x74c, 0x00000030)
# Control
MXC_DCD_ITEM(8, IOMUXC_BASE_ADDR + 0x57c, 0x00000030)
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x590, 0x00003000)
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x598, 0x00003000)
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x58c, 0x00000000)
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x59c, 0x00003030)
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x5a0, 0x00003030)
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x78c, 0x00000030)
# Data Strobe
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x750, 0x00020000)
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x5a8, 0x00000030)
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x5b0, 0x00000030)
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x524, 0x00000030)
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x51c, 0x00000030)
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x518, 0x00000030)
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x50c, 0x00000030)
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x5b8, 0x00000030)
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x5c0, 0x00000030)
# DATA
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x774, 0x00020000)
MXC_DCD_ITEM(25, IOMUXC_BASE_ADDR + 0x784, 0x00000030)
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x788, 0x00000030)
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x794, 0x00000030)
MXC_DCD_ITEM(28, IOMUXC_BASE_ADDR + 0x79c, 0x00000030)
MXC_DCD_ITEM(29, IOMUXC_BASE_ADDR + 0x7a0, 0x00000030)
MXC_DCD_ITEM(30, IOMUXC_BASE_ADDR + 0x7a4, 0x00000030)
MXC_DCD_ITEM(31, IOMUXC_BASE_ADDR + 0x7a8, 0x00000030)
MXC_DCD_ITEM(32, IOMUXC_BASE_ADDR + 0x748, 0x00000030)
MXC_DCD_ITEM(33, IOMUXC_BASE_ADDR + 0x5ac, 0x00000030)
MXC_DCD_ITEM(34, IOMUXC_BASE_ADDR + 0x5b4, 0x00000030)
MXC_DCD_ITEM(35, IOMUXC_BASE_ADDR + 0x528, 0x00000030)
MXC_DCD_ITEM(36, IOMUXC_BASE_ADDR + 0x520, 0x00000030)
MXC_DCD_ITEM(37, IOMUXC_BASE_ADDR + 0x514, 0x00000030)
MXC_DCD_ITEM(38, IOMUXC_BASE_ADDR + 0x510, 0x00000030)
MXC_DCD_ITEM(39, IOMUXC_BASE_ADDR + 0x5bc, 0x00000030)
MXC_DCD_ITEM(40, IOMUXC_BASE_ADDR + 0x5c4, 0x00000030)
# MMDC_P0_BASE_ADDR = 0x021b0000
# MMDC_P1_BASE_ADDR = 0x021b4000
# Calibrations
# ZQ
MXC_DCD_ITEM(41, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(42, MMDC_P1_BASE_ADDR + 0x800, 0xa1390003)
# write leveling
MXC_DCD_ITEM(43, MMDC_P0_BASE_ADDR + 0x80c, 0x001F001F)
MXC_DCD_ITEM(44, MMDC_P0_BASE_ADDR + 0x810, 0x001F001F)
MXC_DCD_ITEM(45, MMDC_P1_BASE_ADDR + 0x80c, 0x00370037)
MXC_DCD_ITEM(46, MMDC_P1_BASE_ADDR + 0x810, 0x00370037)
# DQS gating, read delay, write delay calibration values
# based on calibration compare of 0x00ffff00
MXC_DCD_ITEM(47, MMDC_P0_BASE_ADDR + 0x83c, 0x422f0220)
MXC_DCD_ITEM(48, MMDC_P0_BASE_ADDR + 0x840, 0x021f0219)
MXC_DCD_ITEM(49, MMDC_P1_BASE_ADDR + 0x83C, 0x422f0220)
MXC_DCD_ITEM(50, MMDC_P1_BASE_ADDR + 0x840, 0x022d022f)
MXC_DCD_ITEM(51, MMDC_P0_BASE_ADDR + 0x848, 0x47494b49)
MXC_DCD_ITEM(52, MMDC_P1_BASE_ADDR + 0x848, 0x48484c47)
MXC_DCD_ITEM(53, MMDC_P0_BASE_ADDR + 0x850, 0x39382b2f)
MXC_DCD_ITEM(54, MMDC_P1_BASE_ADDR + 0x850, 0x2f35312c)
# read data bit delay
MXC_DCD_ITEM(55, MMDC_P0_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(56, MMDC_P0_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(57, MMDC_P0_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(58, MMDC_P0_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(59, MMDC_P1_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(60, MMDC_P1_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(61, MMDC_P1_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(62, MMDC_P1_BASE_ADDR + 0x828, 0x33333333)
# Complete calibration by forced measurment
MXC_DCD_ITEM(63, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(64, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
# MMDC init:
# in DDR3, 64-bit mode, only MMDC0 is initiated:
MXC_DCD_ITEM(65, MMDC_P0_BASE_ADDR + 0x004, 0x0002002d)
MXC_DCD_ITEM(66, MMDC_P0_BASE_ADDR + 0x008, 0x00333030)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x00c, 0x40445323)
MXC_DCD_ITEM(68, MMDC_P0_BASE_ADDR + 0x010, 0xb66e8c63)
MXC_DCD_ITEM(69, MMDC_P0_BASE_ADDR + 0x014, 0x01ff00db)
MXC_DCD_ITEM(70, MMDC_P0_BASE_ADDR + 0x018, 0x00081740)
MXC_DCD_ITEM(71, MMDC_P0_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(72, MMDC_P0_BASE_ADDR + 0x02c, 0x000026d2)
MXC_DCD_ITEM(73, MMDC_P0_BASE_ADDR + 0x030, 0x00440e21)
#ifdef CONFIG_DDR_32BIT
MXC_DCD_ITEM(74, MMDC_P0_BASE_ADDR + 0x040, 0x00000017)
MXC_DCD_ITEM(75, MMDC_P0_BASE_ADDR + 0x000, 0xc3190000)
#else
MXC_DCD_ITEM(74, MMDC_P0_BASE_ADDR + 0x040, 0x00000027)
MXC_DCD_ITEM(75, MMDC_P0_BASE_ADDR + 0x000, 0xc31a0000)
#endif
# Initialize 2GB DDR3 - Micron MT41J128M
# MR2
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x01c, 0x04008032)
MXC_DCD_ITEM(77, MMDC_P0_BASE_ADDR + 0x01c, 0x0400803a)
# MR3
MXC_DCD_ITEM(78, MMDC_P0_BASE_ADDR + 0x01c, 0x00008033)
MXC_DCD_ITEM(79, MMDC_P0_BASE_ADDR + 0x01c, 0x0000803b)
# MR1
MXC_DCD_ITEM(80, MMDC_P0_BASE_ADDR + 0x01c, 0x00428031)
MXC_DCD_ITEM(81, MMDC_P0_BASE_ADDR + 0x01c, 0x00428039)
# MR0
MXC_DCD_ITEM(82, MMDC_P0_BASE_ADDR + 0x01c, 0x07208030)
MXC_DCD_ITEM(83, MMDC_P0_BASE_ADDR + 0x01c, 0x07208038)
# ZQ calibration
MXC_DCD_ITEM(84, MMDC_P0_BASE_ADDR + 0x01c, 0x04008040)
MXC_DCD_ITEM(85, MMDC_P0_BASE_ADDR + 0x01c, 0x04008048)
# final DDR setup
MXC_DCD_ITEM(86, MMDC_P0_BASE_ADDR + 0x020, 0x00005800)
MXC_DCD_ITEM(87, MMDC_P0_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(88, MMDC_P1_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(89, MMDC_P0_BASE_ADDR + 0x004, 0x0002556d)
MXC_DCD_ITEM(90, MMDC_P1_BASE_ADDR + 0x004, 0x00011006)
MXC_DCD_ITEM(91, MMDC_P0_BASE_ADDR + 0x01c, 0x00000000)
#elif defined CONFIG_MX6DL_LPDDR2
dcd_hdr:          .word 0x408803D2 /* Tag=0xD2, Len=112*8 + 4 + 4, Ver=0x40 */
write_dcd_cmd:    .word 0x048403CC /* Tag=0xCC, Len=112*8 + 4, Param=0x04 */
# IOMUX SETTINGS
# IOMUXC_BASE_ADDR = 0x020e0000
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0 */
MXC_DCD_ITEM(1, IOMUXC_BASE_ADDR + 0x4bc, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1 */
MXC_DCD_ITEM(2, IOMUXC_BASE_ADDR + 0x4c0, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2 */
MXC_DCD_ITEM(3, IOMUXC_BASE_ADDR + 0x4c4, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3 */
MXC_DCD_ITEM(4, IOMUXC_BASE_ADDR + 0x4c8, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS4 */
MXC_DCD_ITEM(5, IOMUXC_BASE_ADDR + 0x4cc, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS5 */
MXC_DCD_ITEM(6, IOMUXC_BASE_ADDR + 0x4d0, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS6 */
MXC_DCD_ITEM(7, IOMUXC_BASE_ADDR + 0x4d4, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS7 */
MXC_DCD_ITEM(8, IOMUXC_BASE_ADDR + 0x4d8, 0x00003028)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0 */
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x470, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1 */
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x474, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2 */
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x478, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3 */
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x47c, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM4 */
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x480, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM5 */
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x484, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM6 */
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x488, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM7 */
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x48c, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS */
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x464, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS */
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x490, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0 */
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x4ac, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_1 */
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x4b0, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET */
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x494, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCKE0 */
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x4a4, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCKE1 */
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x4a8, 0x00000038)
* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2
* DSE can be configured using Group Control Register:
* IOMUXC_SW_PAD_CTL_GRP_CTLDS
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x4a0, 0x00000000)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0 */
MXC_DCD_ITEM(25, IOMUXC_BASE_ADDR + 0x4b4, 0x00000038)
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1 */
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x4b8, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B0DS */
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x764, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B1DS */
MXC_DCD_ITEM(28, IOMUXC_BASE_ADDR + 0x770, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B2DS */
MXC_DCD_ITEM(29, IOMUXC_BASE_ADDR + 0x778, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B3DS */
MXC_DCD_ITEM(30, IOMUXC_BASE_ADDR + 0x77c, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B4DS */
MXC_DCD_ITEM(31, IOMUXC_BASE_ADDR + 0x780, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B5DS */
MXC_DCD_ITEM(32, IOMUXC_BASE_ADDR + 0x784, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B6DS */
MXC_DCD_ITEM(33, IOMUXC_BASE_ADDR + 0x78c, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_B7DS */
MXC_DCD_ITEM(34, IOMUXC_BASE_ADDR + 0x748, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_ADDDS */
MXC_DCD_ITEM(35, IOMUXC_BASE_ADDR + 0x74c, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_CTLDS */
MXC_DCD_ITEM(36, IOMUXC_BASE_ADDR + 0x76c, 0x00000038)
/* IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL */
MXC_DCD_ITEM(37, IOMUXC_BASE_ADDR + 0x750, 0x00020000)
/* IOMUXC_SW_PAD_CTL_GRP_DDRPKE */
MXC_DCD_ITEM(38, IOMUXC_BASE_ADDR + 0x754, 0x00000000)
/* IOMUXC_SW_PAD_CTL_GRP_DDRMODE */
MXC_DCD_ITEM(39, IOMUXC_BASE_ADDR + 0x760, 0x00020000)
/* IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE */
MXC_DCD_ITEM(40, IOMUXC_BASE_ADDR + 0x774, 0x00080000)
* DDR Controller Registers
* Manufacturer: Mocron
* Device Part Number: MT42L64M64D2KH-18
* Clock Freq.: 528MHz
* MMDC channels: Both MMDC0, MMDC1
*Density per CS in Gb: 256M
* Chip Selects used: 2
* Number of Banks: 8
* Row address:     14
* Column address: 9
* Data bus width 32
/* MMDC0_MDSCR, set the Configuration request bit during MMDC set up */
MXC_DCD_ITEM(41, MMDC_P0_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(42, MMDC_P1_BASE_ADDR + 0x01c, 0x00008000)
/*LPDDR2 ZQ params */
MXC_DCD_ITEM(43, MMDC_P0_BASE_ADDR + 0x85c, 0x1b5f01ff)
MXC_DCD_ITEM(44, MMDC_P1_BASE_ADDR + 0x85c, 0x1b5f01ff)
# Calibration setup.
/* DDR_PHY_P0_MPZQHWCTRL, enable on time ZQ calibration */
MXC_DCD_ITEM(45, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
/*ca bus abs delay */
MXC_DCD_ITEM(46, MMDC_P0_BASE_ADDR + 0x890, 0x00400000)
MXC_DCD_ITEM(47, MMDC_P1_BASE_ADDR + 0x890, 0x00400000)
/* values of 20,40,50,60,7f tried. no difference seen */
/* DDR_PHY_P1_MPWRCADL */
MXC_DCD_ITEM(48, MMDC_P1_BASE_ADDR + 0x8bc, 0x00055555)
/*frc_msr.*/
MXC_DCD_ITEM(49, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
/*frc_msr.*/
MXC_DCD_ITEM(50, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
/* DDR_PHY_P0_MPREDQBY0DL3 */
MXC_DCD_ITEM(51, MMDC_P0_BASE_ADDR + 0x81c, 0x33333333)
/* DDR_PHY_P0_MPREDQBY1DL3 */
MXC_DCD_ITEM(52, MMDC_P0_BASE_ADDR + 0x820, 0x33333333)
/* DDR_PHY_P0_MPREDQBY2DL3 */
MXC_DCD_ITEM(53, MMDC_P0_BASE_ADDR + 0x824, 0x33333333)
/* DDR_PHY_P0_MPREDQBY3DL3 */
MXC_DCD_ITEM(54, MMDC_P0_BASE_ADDR + 0x828, 0x33333333)
/* DDR_PHY_P1_MPREDQBY0DL3 */
MXC_DCD_ITEM(55, MMDC_P1_BASE_ADDR + 0x81c, 0x33333333)
/* DDR_PHY_P1_MPREDQBY1DL3 */
MXC_DCD_ITEM(56, MMDC_P1_BASE_ADDR + 0x820, 0x33333333)
/* DDR_PHY_P1_MPREDQBY2DL3 */
MXC_DCD_ITEM(57, MMDC_P1_BASE_ADDR + 0x824, 0x33333333)
/* DDR_PHY_P1_MPREDQBY3DL3 */
MXC_DCD_ITEM(58, MMDC_P1_BASE_ADDR + 0x828, 0x33333333)
* Read and write data delay, per byte.
* For optimized DDR operation it is recommended to run mmdc_calibration
* on your board, and replace 4 delay register assigns with resulted values
* Note:
* a. DQS gating is not relevant for LPDDR2. DSQ gating calibration section
*    should be skipped, or the write/read calibration comming after that
*    will stall
* b. The calibration code that runs for both MMDC0 & MMDC1 should be used.
MXC_DCD_ITEM(59, MMDC_P0_BASE_ADDR + 0x848, 0x4b4b524f)
MXC_DCD_ITEM(60, MMDC_P1_BASE_ADDR + 0x848, 0x494f4c44)
MXC_DCD_ITEM(61, MMDC_P0_BASE_ADDR + 0x850, 0x3c3d303c)
MXC_DCD_ITEM(62, MMDC_P1_BASE_ADDR + 0x850, 0x3c343d38)
/*dqs gating dis */
MXC_DCD_ITEM(63, MMDC_P0_BASE_ADDR + 0x83c, 0x20000000)
MXC_DCD_ITEM(64, MMDC_P0_BASE_ADDR + 0x840, 0x0)
MXC_DCD_ITEM(65, MMDC_P1_BASE_ADDR + 0x83c, 0x20000000)
MXC_DCD_ITEM(66, MMDC_P1_BASE_ADDR + 0x840, 0x0)
/*clk delay */
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x858, 0xa00)
/*clk delay */
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x858, 0xa00)
/*frc_msr */
MXC_DCD_ITEM(69, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
/*frc_msr */
MXC_DCD_ITEM(70, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
# Calibration setup end
/* Channel0 - startng address 0x80000000 */
/* MMDC0_MDCFG0 */
MXC_DCD_ITEM(71, MMDC_P0_BASE_ADDR + 0x00c, 0x34386145)
/* MMDC0_MDPDC */
MXC_DCD_ITEM(72, MMDC_P0_BASE_ADDR + 0x004, 0x00020036)
/* MMDC0_MDCFG1 */
MXC_DCD_ITEM(73, MMDC_P0_BASE_ADDR + 0x010, 0x00100c83)
/* MMDC0_MDCFG2 */
MXC_DCD_ITEM(74, MMDC_P0_BASE_ADDR + 0x014, 0x000000Dc)
/* MMDC0_MDMISC */
MXC_DCD_ITEM(75, MMDC_P0_BASE_ADDR + 0x018, 0x0000174C)
/* MMDC0_MDRWD;*/
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x02c, 0x0f9f26d2)
/* MMDC0_MDOR */
MXC_DCD_ITEM(77, MMDC_P0_BASE_ADDR + 0x030, 0x0000020e)
/* MMDC0_MDCFG3LP */
MXC_DCD_ITEM(78, MMDC_P0_BASE_ADDR + 0x038, 0x00190778)
/* MMDC0_MDOTC */
MXC_DCD_ITEM(79, MMDC_P0_BASE_ADDR + 0x008, 0x00000000)
/* CS0_END */
MXC_DCD_ITEM(80, MMDC_P0_BASE_ADDR + 0x040, 0x0000005f)
/* ROC */
MXC_DCD_ITEM(81, MMDC_P0_BASE_ADDR + 0x404, 0x0000000f)
/* MMDC0_MDCTL */
MXC_DCD_ITEM(82, MMDC_P0_BASE_ADDR + 0x000, 0xc3010000)
/* Channel1 - starting address 0x10000000 */
/* MMDC1_MDCFG0 */
MXC_DCD_ITEM(83, MMDC_P1_BASE_ADDR + 0x00c, 0x34386145)
/* MMDC1_MDPDC */
MXC_DCD_ITEM(84, MMDC_P1_BASE_ADDR + 0x004, 0x00020036)
/* MMDC1_MDCFG1 */
MXC_DCD_ITEM(85, MMDC_P1_BASE_ADDR + 0x010, 0x00100c83)
/* MMDC1_MDCFG2 */
MXC_DCD_ITEM(86, MMDC_P1_BASE_ADDR + 0x014, 0x000000Dc)
/* MMDC1_MDMISC */
MXC_DCD_ITEM(87, MMDC_P1_BASE_ADDR + 0x018, 0x0000174C)
/* MMDC1_MDRWD;*/
MXC_DCD_ITEM(88, MMDC_P1_BASE_ADDR + 0x02c, 0x0f9f26d2)
/* MMDC1_MDOR */
MXC_DCD_ITEM(89, MMDC_P1_BASE_ADDR + 0x030, 0x0000020e)
/* MMDC1_MDCFG3LP */
MXC_DCD_ITEM(90, MMDC_P1_BASE_ADDR + 0x038, 0x00190778)
/* MMDC1_MDOTC */
MXC_DCD_ITEM(91, MMDC_P1_BASE_ADDR + 0x008, 0x00000000)
/* CS0_END */
MXC_DCD_ITEM(92, MMDC_P1_BASE_ADDR + 0x040, 0x0000003f)
/* MMDC1_MDCTL */
MXC_DCD_ITEM(93, MMDC_P1_BASE_ADDR + 0x000, 0xc3010000)
/* Channel0 : Configure DDR device:*/
/* MRW: BA=0 CS=0 MR_ADDR=63 MR_OP=0 */
MXC_DCD_ITEM(94, MMDC_P0_BASE_ADDR + 0x01c, 0x003f8030)
/* MRW: BA=0 CS=0 MR_ADDR=10 MR_OP=ff */
MXC_DCD_ITEM(95, MMDC_P0_BASE_ADDR + 0x01c, 0xff0a8030)
/* MRW: BA=0 CS=0 MR_ADDR=1  MR_OP=a2 */
MXC_DCD_ITEM(96, MMDC_P0_BASE_ADDR + 0x01c, 0xa2018030)
/* MRW: BA=0 CS=0 MR_ADDR=2  MR_OP=6. tcl=8, tcwl=4 */
MXC_DCD_ITEM(97, MMDC_P0_BASE_ADDR + 0x01c, 0x06028030)
/* MRW: BA=0 CS=0 MR_ADDR=3  MR_OP=2.drive=240/6 */
MXC_DCD_ITEM(98, MMDC_P0_BASE_ADDR + 0x01c, 0x01038030)
/* Channel1 : Configure DDR device:*/
MXC_DCD_ITEM(99, MMDC_P1_BASE_ADDR + 0x01c, 0x003f8030)
MXC_DCD_ITEM(100, MMDC_P1_BASE_ADDR + 0x01c, 0xff0a8030)
MXC_DCD_ITEM(101, MMDC_P1_BASE_ADDR + 0x01c, 0xa2018030)
MXC_DCD_ITEM(102, MMDC_P1_BASE_ADDR + 0x01c, 0x06028030)
MXC_DCD_ITEM(103, MMDC_P1_BASE_ADDR + 0x01c, 0x01038030)
/* MMDC0_MDREF */
MXC_DCD_ITEM(104, MMDC_P0_BASE_ADDR + 0x020, 0x00005800)
/* MMDC1_MDREF */
MXC_DCD_ITEM(105, MMDC_P1_BASE_ADDR + 0x020, 0x00005800)
/* DDR_PHY_P0_MPODTCTRL */
MXC_DCD_ITEM(106, MMDC_P0_BASE_ADDR + 0x818, 0x0)
/* DDR_PHY_P1_MPODTCTRL */
MXC_DCD_ITEM(107, MMDC_P1_BASE_ADDR + 0x818, 0x0)
* calibration values based on calibration compare of 0x00ffff00:
* Note, these calibration values are based on Freescale's board
* May need to run calibration on target board to fine tune these
/* DDR_PHY_P0_MPZQHWCTRL, enable automatic ZQ calibration */
MXC_DCD_ITEM(108, MMDC_P0_BASE_ADDR + 0x800, 0xa1310003)
/* DDR_PHY_P0_MPMUR0, frc_msr */
MXC_DCD_ITEM(109, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
/* DDR_PHY_P1_MPMUR0, frc_msr */
MXC_DCD_ITEM(110, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
* MMDC0_MDSCR, clear this register
* (especially the configuration bit as initialization is complete)
MXC_DCD_ITEM(111, MMDC_P0_BASE_ADDR + 0x01c, 0x00000000)
MXC_DCD_ITEM(112, MMDC_P1_BASE_ADDR + 0x01c, 0x00000000)
#elif defined(CONFIG_LPDDR2)
dcd_hdr:          .word 0x40F003D2 /* Tag=0xD2, Len=125*8 + 4 + 4, Ver=0x40 */
write_dcd_cmd:    .word 0x04EC03CC /* Tag=0xCC, Len=125*8 + 4, Param=0x04 */
/* DCD */
MXC_DCD_ITEM(1, CCM_BASE_ADDR + 0x18, 0x60324)
MXC_DCD_ITEM(2, IOMUXC_BASE_ADDR + 0x5a8, 0x00003038)
MXC_DCD_ITEM(3, IOMUXC_BASE_ADDR + 0x5b0, 0x00003038)
MXC_DCD_ITEM(4, IOMUXC_BASE_ADDR + 0x524, 0x00003038)
MXC_DCD_ITEM(5, IOMUXC_BASE_ADDR + 0x51c, 0x00003038)
MXC_DCD_ITEM(6, IOMUXC_BASE_ADDR + 0x518, 0x00003038)
MXC_DCD_ITEM(7, IOMUXC_BASE_ADDR + 0x50c, 0x00003038)
MXC_DCD_ITEM(8, IOMUXC_BASE_ADDR + 0x5b8, 0x00003038)
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x5c0, 0x00003038)
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x5ac, 0x00000038)
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x5b4, 0x00000038)
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x528, 0x00000038)
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x520, 0x00000038)
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x514, 0x00000038)
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x510, 0x00000038)
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x5bc, 0x00000038)
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x5c4, 0x00000038)
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x56c, 0x00000038)
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x578, 0x00000038)
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x588, 0x00000038)
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x594, 0x00000038)
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x57c, 0x00000038)
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x590, 0x00000038)
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x598, 0x00000038)
MXC_DCD_ITEM(25, IOMUXC_BASE_ADDR + 0x58c, 0x00000000)
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x59c, 0x00000038)
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x5a0, 0x00000038)
MXC_DCD_ITEM(28, IOMUXC_BASE_ADDR + 0x784, 0x00000038)
MXC_DCD_ITEM(29, IOMUXC_BASE_ADDR + 0x788, 0x00000038)
MXC_DCD_ITEM(30, IOMUXC_BASE_ADDR + 0x794, 0x00000038)
MXC_DCD_ITEM(31, IOMUXC_BASE_ADDR + 0x79c, 0x00000038)
MXC_DCD_ITEM(32, IOMUXC_BASE_ADDR + 0x7a0, 0x00000038)
MXC_DCD_ITEM(33, IOMUXC_BASE_ADDR + 0x7a4, 0x00000038)
MXC_DCD_ITEM(34, IOMUXC_BASE_ADDR + 0x7a8, 0x00000038)
MXC_DCD_ITEM(35, IOMUXC_BASE_ADDR + 0x748, 0x00000038)
MXC_DCD_ITEM(36, IOMUXC_BASE_ADDR + 0x74c, 0x00000038)
MXC_DCD_ITEM(38, IOMUXC_BASE_ADDR + 0x758, 0x00000000)
MXC_DCD_ITEM(39, IOMUXC_BASE_ADDR + 0x774, 0x00020000)
MXC_DCD_ITEM(40, IOMUXC_BASE_ADDR + 0x78c, 0x00000038)
MXC_DCD_ITEM(41, IOMUXC_BASE_ADDR + 0x798, 0x00080000)
MXC_DCD_ITEM(42, MMDC_P0_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(43, MMDC_P1_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(44, MMDC_P0_BASE_ADDR + 0x85c, 0x1b5f01ff)
MXC_DCD_ITEM(45, MMDC_P1_BASE_ADDR + 0x85c, 0x1b5f01ff)
MXC_DCD_ITEM(46, MMDC_P0_BASE_ADDR + 0x800, 0xa1390000)
MXC_DCD_ITEM(47, MMDC_P1_BASE_ADDR + 0x800, 0xa1390000)
MXC_DCD_ITEM(48, MMDC_P0_BASE_ADDR + 0x890, 0x00400000)
MXC_DCD_ITEM(49, MMDC_P1_BASE_ADDR + 0x890, 0x00400000)
MXC_DCD_ITEM(50, MMDC_P1_BASE_ADDR + 0x8bc, 0x00055555)
MXC_DCD_ITEM(51, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(52, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(53, MMDC_P0_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(54, MMDC_P0_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(55, MMDC_P0_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(56, MMDC_P0_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(57, MMDC_P1_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(58, MMDC_P1_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(59, MMDC_P1_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(60, MMDC_P1_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(61, MMDC_P0_BASE_ADDR + 0x82c, 0xf3333333)
MXC_DCD_ITEM(62, MMDC_P0_BASE_ADDR + 0x830, 0xf3333333)
MXC_DCD_ITEM(63, MMDC_P0_BASE_ADDR + 0x834, 0xf3333333)
MXC_DCD_ITEM(64, MMDC_P0_BASE_ADDR + 0x838, 0xf3333333)
MXC_DCD_ITEM(65, MMDC_P1_BASE_ADDR + 0x82c, 0xf3333333)
MXC_DCD_ITEM(66, MMDC_P1_BASE_ADDR + 0x830, 0xf3333333)
MXC_DCD_ITEM(67, MMDC_P1_BASE_ADDR + 0x834, 0xf3333333)
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x838, 0xf3333333)
MXC_DCD_ITEM(69, MMDC_P0_BASE_ADDR + 0x848, 0x49383b39)
MXC_DCD_ITEM(70, MMDC_P0_BASE_ADDR + 0x850, 0x30364738)
MXC_DCD_ITEM(71, MMDC_P1_BASE_ADDR + 0x848, 0x3e3c3846)
MXC_DCD_ITEM(72, MMDC_P1_BASE_ADDR + 0x850, 0x4c294b35)
MXC_DCD_ITEM(73, MMDC_P0_BASE_ADDR + 0x83c, 0x20000000)
MXC_DCD_ITEM(74, MMDC_P0_BASE_ADDR + 0x840, 0x0)
MXC_DCD_ITEM(75, MMDC_P1_BASE_ADDR + 0x83c, 0x20000000)
MXC_DCD_ITEM(76, MMDC_P1_BASE_ADDR + 0x840, 0x0)
MXC_DCD_ITEM(77, MMDC_P0_BASE_ADDR + 0x858, 0xf00)
MXC_DCD_ITEM(78, MMDC_P1_BASE_ADDR + 0x858, 0xf00)
MXC_DCD_ITEM(79, MMDC_P0_BASE_ADDR + 0x8b8, 0x800)
MXC_DCD_ITEM(80, MMDC_P1_BASE_ADDR + 0x8b8, 0x800)
MXC_DCD_ITEM(81, MMDC_P0_BASE_ADDR + 0xc, 0x555a61a5)
MXC_DCD_ITEM(82, MMDC_P0_BASE_ADDR + 0x4, 0x20036)
MXC_DCD_ITEM(83, MMDC_P0_BASE_ADDR + 0x10, 0x160e83)
MXC_DCD_ITEM(84, MMDC_P0_BASE_ADDR + 0x14, 0xdd)
MXC_DCD_ITEM(85, MMDC_P0_BASE_ADDR + 0x18, 0x8174c)
MXC_DCD_ITEM(86, MMDC_P0_BASE_ADDR + 0x2c, 0xf9f26d2)
MXC_DCD_ITEM(87, MMDC_P0_BASE_ADDR + 0x30, 0x20e)
MXC_DCD_ITEM(88, MMDC_P0_BASE_ADDR + 0x38, 0x200aac)
MXC_DCD_ITEM(89, MMDC_P0_BASE_ADDR + 0x8, 0x0)
MXC_DCD_ITEM(90, MMDC_P0_BASE_ADDR + 0x40, 0x5f)
MXC_DCD_ITEM(91, MMDC_P0_BASE_ADDR + 0x0, 0xc3010000)
MXC_DCD_ITEM(92, MMDC_P1_BASE_ADDR + 0xc, 0x555a61a5)
MXC_DCD_ITEM(93, MMDC_P1_BASE_ADDR + 0x4, 0x20036)
MXC_DCD_ITEM(94, MMDC_P1_BASE_ADDR + 0x10, 0x160e83)
MXC_DCD_ITEM(95, MMDC_P1_BASE_ADDR + 0x14, 0xdd)
MXC_DCD_ITEM(96, MMDC_P1_BASE_ADDR + 0x18, 0x8174c)
MXC_DCD_ITEM(97, MMDC_P1_BASE_ADDR + 0x2c, 0xf9f26d2)
MXC_DCD_ITEM(98, MMDC_P1_BASE_ADDR + 0x30, 0x20e)
MXC_DCD_ITEM(99, MMDC_P1_BASE_ADDR + 0x38, 0x200aac)
MXC_DCD_ITEM(100, MMDC_P1_BASE_ADDR + 0x8, 0x0)
MXC_DCD_ITEM(101, MMDC_P1_BASE_ADDR + 0x40, 0x3f)
MXC_DCD_ITEM(102, MMDC_P1_BASE_ADDR + 0x0, 0xc3010000)
MXC_DCD_ITEM(103, MMDC_P0_BASE_ADDR + 0x1c, 0x3f8030)
MXC_DCD_ITEM(104, MMDC_P0_BASE_ADDR + 0x1c, 0xff0a8030)
MXC_DCD_ITEM(105, MMDC_P0_BASE_ADDR + 0x1c, 0xc2018030)
MXC_DCD_ITEM(106, MMDC_P0_BASE_ADDR + 0x1c, 0x6028030)
MXC_DCD_ITEM(107, MMDC_P0_BASE_ADDR + 0x1c, 0x2038030)
MXC_DCD_ITEM(108, MMDC_P1_BASE_ADDR + 0x1c, 0x3f8030)
MXC_DCD_ITEM(109, MMDC_P1_BASE_ADDR + 0x1c, 0xff0a8030)
MXC_DCD_ITEM(110, MMDC_P1_BASE_ADDR + 0x1c, 0xc2018030)
MXC_DCD_ITEM(111, MMDC_P1_BASE_ADDR + 0x1c, 0x6028030)
MXC_DCD_ITEM(112, MMDC_P1_BASE_ADDR + 0x1c, 0x2038030)
MXC_DCD_ITEM(113, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(114, MMDC_P1_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(115, MMDC_P0_BASE_ADDR + 0x20, 0x7800)
MXC_DCD_ITEM(116, MMDC_P1_BASE_ADDR + 0x20, 0x7800)
MXC_DCD_ITEM(117, MMDC_P0_BASE_ADDR + 0x818, 0x0)
MXC_DCD_ITEM(118, MMDC_P1_BASE_ADDR + 0x818, 0x0)
MXC_DCD_ITEM(119, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(120, MMDC_P1_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(121, MMDC_P0_BASE_ADDR + 0x8b8, 0x800)
MXC_DCD_ITEM(122, MMDC_P1_BASE_ADDR + 0x8b8, 0x800)
MXC_DCD_ITEM(123, MMDC_P0_BASE_ADDR + 0x1c, 0x0)
MXC_DCD_ITEM(124, MMDC_P1_BASE_ADDR + 0x1c, 0x0)
MXC_DCD_ITEM(125, MMDC_P0_BASE_ADDR + 0x404, 0x00011006)
#elif defined CONFIG_LPDDR2POP
write_dcd_cmd:    .word 0x04E403CC /* Tag=0xCC, Len=125*8 + 4, Param=0x04 */
# CCM_BASE_ADDR = 0x020c4000
MXC_DCD_ITEM(1, CCM_BASE_ADDR + 0x068, 0xffffffff)
MXC_DCD_ITEM(2, CCM_BASE_ADDR + 0x06c, 0xffffffff)
MXC_DCD_ITEM(3, CCM_BASE_ADDR + 0x070, 0xffffffff)
MXC_DCD_ITEM(4, CCM_BASE_ADDR + 0x074, 0xffffffff)
MXC_DCD_ITEM(5, CCM_BASE_ADDR + 0x078, 0xffffffff)
MXC_DCD_ITEM(6, CCM_BASE_ADDR + 0x07c, 0xffffffff)
MXC_DCD_ITEM(7, CCM_BASE_ADDR + 0x080, 0xffffffff)
MXC_DCD_ITEM(8, CCM_BASE_ADDR + 0x084, 0xffffffff)
#Switch PL301_FAST2 to DDR Dual-channel mapping
#However, it is not accessable by DCD, consider put it later in "dram_init"
# GPV0_BASE_ADDR = 0x00B00000
/*MXC_DCD_ITEM(9, GPV0_BASE_ADDR, 0x00000001)*/
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x774, 0x00020000)
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x758, 0x00000000)
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x588, 0x00000038)
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x594, 0x00000038)
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x56c, 0x00000038)
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x578, 0x00000038)
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x57c, 0x00000038)
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x590, 0x00000038)
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x598, 0x00000038)
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x58c, 0x00000000)
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x59c, 0x00000038)
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x5a0, 0x00000038)
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x74c, 0x00000038)
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x78c, 0x00000038)
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x750, 0x00020000)
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x5a8, 0x00003038)
MXC_DCD_ITEM(25, IOMUXC_BASE_ADDR + 0x5b0, 0x00003038)
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x524, 0x00003038)
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x51c, 0x00003038)
MXC_DCD_ITEM(28, IOMUXC_BASE_ADDR + 0x518, 0x00003038)
MXC_DCD_ITEM(29, IOMUXC_BASE_ADDR + 0x50c, 0x00003038)
MXC_DCD_ITEM(30, IOMUXC_BASE_ADDR + 0x5b8, 0x00003038)
MXC_DCD_ITEM(31, IOMUXC_BASE_ADDR + 0x5c0, 0x00003038)
MXC_DCD_ITEM(32, IOMUXC_BASE_ADDR + 0x798, 0x00080000)
MXC_DCD_ITEM(33, IOMUXC_BASE_ADDR + 0x784, 0x00000038)
MXC_DCD_ITEM(34, IOMUXC_BASE_ADDR + 0x788, 0x00000038)
MXC_DCD_ITEM(35, IOMUXC_BASE_ADDR + 0x794, 0x00000038)
MXC_DCD_ITEM(36, IOMUXC_BASE_ADDR + 0x79c, 0x00000038)
MXC_DCD_ITEM(37, IOMUXC_BASE_ADDR + 0x7a0, 0x00000038)
MXC_DCD_ITEM(38, IOMUXC_BASE_ADDR + 0x7a4, 0x00000038)
MXC_DCD_ITEM(39, IOMUXC_BASE_ADDR + 0x7a8, 0x00000038)
MXC_DCD_ITEM(40, IOMUXC_BASE_ADDR + 0x748, 0x00000038)
MXC_DCD_ITEM(41, IOMUXC_BASE_ADDR + 0x5ac, 0x00000038)
MXC_DCD_ITEM(42, IOMUXC_BASE_ADDR + 0x5b4, 0x00000038)
MXC_DCD_ITEM(43, IOMUXC_BASE_ADDR + 0x528, 0x00000038)
MXC_DCD_ITEM(44, IOMUXC_BASE_ADDR + 0x520, 0x00000038)
MXC_DCD_ITEM(45, IOMUXC_BASE_ADDR + 0x514, 0x00000038)
MXC_DCD_ITEM(46, IOMUXC_BASE_ADDR + 0x510, 0x00000038)
MXC_DCD_ITEM(47, IOMUXC_BASE_ADDR + 0x5bc, 0x00000038)
MXC_DCD_ITEM(48, IOMUXC_BASE_ADDR + 0x5c4, 0x00000038)
MXC_DCD_ITEM(49, MMDC_P0_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(50, MMDC_P1_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(51, MMDC_P0_BASE_ADDR + 0x85c, 0x1b5f01ff)
MXC_DCD_ITEM(52, MMDC_P1_BASE_ADDR + 0x85c, 0x1b5f01ff)
MXC_DCD_ITEM(53, MMDC_P0_BASE_ADDR + 0x800, 0xa1390000)
MXC_DCD_ITEM(54, MMDC_P1_BASE_ADDR + 0x800, 0xa1390000)
MXC_DCD_ITEM(55, MMDC_P1_BASE_ADDR + 0x8bc, 0x00055555)
MXC_DCD_ITEM(56, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(57, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(58, MMDC_P1_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(59, MMDC_P1_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(60, MMDC_P1_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(61, MMDC_P1_BASE_ADDR + 0x828, 0x33333303)
MXC_DCD_ITEM(62, MMDC_P0_BASE_ADDR + 0x82c, 0xf3333333)
MXC_DCD_ITEM(63, MMDC_P0_BASE_ADDR + 0x830, 0xf3333333)
MXC_DCD_ITEM(64, MMDC_P0_BASE_ADDR + 0x834, 0xf3333333)
MXC_DCD_ITEM(65, MMDC_P0_BASE_ADDR + 0x838, 0xf3333333)
MXC_DCD_ITEM(66, MMDC_P1_BASE_ADDR + 0x82c, 0xf3333333)
MXC_DCD_ITEM(67, MMDC_P1_BASE_ADDR + 0x830, 0xf3333333)
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x834, 0xf3333333)
MXC_DCD_ITEM(69, MMDC_P1_BASE_ADDR + 0x838, 0xf3333303)
MXC_DCD_ITEM(70, MMDC_P0_BASE_ADDR + 0x848, 0x39313035)
MXC_DCD_ITEM(71, MMDC_P1_BASE_ADDR + 0x848, 0x39313c42)
MXC_DCD_ITEM(72, MMDC_P0_BASE_ADDR + 0x850, 0x2e424a44)
MXC_DCD_ITEM(73, MMDC_P1_BASE_ADDR + 0x850, 0x4c374640)
MXC_DCD_ITEM(74, MMDC_P0_BASE_ADDR + 0x83c, 0x20000000)
MXC_DCD_ITEM(75, MMDC_P0_BASE_ADDR + 0x840, 0x00000000)
MXC_DCD_ITEM(76, MMDC_P1_BASE_ADDR + 0x83c, 0x20000000)
MXC_DCD_ITEM(77, MMDC_P1_BASE_ADDR + 0x840, 0x00000000)
MXC_DCD_ITEM(78, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(79, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(80, MMDC_P0_BASE_ADDR + 0x00c, 0x555A61A5)
MXC_DCD_ITEM(81, MMDC_P0_BASE_ADDR + 0x004, 0x00020036)
MXC_DCD_ITEM(82, MMDC_P0_BASE_ADDR + 0x010, 0x00160E83)
MXC_DCD_ITEM(83, MMDC_P0_BASE_ADDR + 0x014, 0x000000DD)
MXC_DCD_ITEM(84, MMDC_P0_BASE_ADDR + 0x018, 0x0000174C)
MXC_DCD_ITEM(85, MMDC_P0_BASE_ADDR + 0x02c, 0x0f9f26d2)
MXC_DCD_ITEM(86, MMDC_P0_BASE_ADDR + 0x030, 0x0000020e)
MXC_DCD_ITEM(87, MMDC_P0_BASE_ADDR + 0x038, 0x00220aac)
MXC_DCD_ITEM(88, MMDC_P0_BASE_ADDR + 0x008, 0x00000000)
MXC_DCD_ITEM(89, MMDC_P0_BASE_ADDR + 0x040, 0x0000005f)
MXC_DCD_ITEM(90, MMDC_P0_BASE_ADDR + 0x000, 0xc3010000)
MXC_DCD_ITEM(91, MMDC_P1_BASE_ADDR + 0x00c, 0x555A61A5)
MXC_DCD_ITEM(92, MMDC_P1_BASE_ADDR + 0x004, 0x00020036)
MXC_DCD_ITEM(93, MMDC_P1_BASE_ADDR + 0x010, 0x00160E83)
MXC_DCD_ITEM(94, MMDC_P1_BASE_ADDR + 0x014, 0x000000DD)
MXC_DCD_ITEM(95, MMDC_P1_BASE_ADDR + 0x018, 0x0000174C)
MXC_DCD_ITEM(96, MMDC_P1_BASE_ADDR + 0x02c, 0x0f9f26d2)
MXC_DCD_ITEM(97, MMDC_P1_BASE_ADDR + 0x030, 0x0000020e)
MXC_DCD_ITEM(98, MMDC_P1_BASE_ADDR + 0x038, 0x00220aac)
MXC_DCD_ITEM(99, MMDC_P1_BASE_ADDR + 0x008, 0x00000000)
MXC_DCD_ITEM(100, MMDC_P1_BASE_ADDR + 0x040, 0x0000003f)
MXC_DCD_ITEM(101, MMDC_P1_BASE_ADDR + 0x000, 0xc3010000)
MXC_DCD_ITEM(102, MMDC_P0_BASE_ADDR + 0x01c, 0x003f8030)
MXC_DCD_ITEM(103, MMDC_P0_BASE_ADDR + 0x01c, 0xff0a8030)
MXC_DCD_ITEM(104, MMDC_P0_BASE_ADDR + 0x01c, 0xc2018030)
MXC_DCD_ITEM(105, MMDC_P0_BASE_ADDR + 0x01c, 0x06028030)
MXC_DCD_ITEM(106, MMDC_P0_BASE_ADDR + 0x01c, 0x01038030)
MXC_DCD_ITEM(107, MMDC_P1_BASE_ADDR + 0x01c, 0x003f8030)
MXC_DCD_ITEM(108, MMDC_P1_BASE_ADDR + 0x01c, 0xff0a8030)
MXC_DCD_ITEM(109, MMDC_P1_BASE_ADDR + 0x01c, 0xc2018030)
MXC_DCD_ITEM(110, MMDC_P1_BASE_ADDR + 0x01c, 0x06028030)
MXC_DCD_ITEM(111, MMDC_P1_BASE_ADDR + 0x01c, 0x01038030)
MXC_DCD_ITEM(112, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(113, MMDC_P1_BASE_ADDR + 0x800, 0xa1390003)
MXC_DCD_ITEM(114, MMDC_P0_BASE_ADDR + 0x020, 0x00007800)
MXC_DCD_ITEM(115, MMDC_P1_BASE_ADDR + 0x020, 0x00007800)
MXC_DCD_ITEM(116, MMDC_P0_BASE_ADDR + 0x818, 0x00000000)
MXC_DCD_ITEM(117, MMDC_P1_BASE_ADDR + 0x818, 0x00000000)
MXC_DCD_ITEM(118, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(119, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(120, MMDC_P0_BASE_ADDR + 0x004, 0x00025576)
MXC_DCD_ITEM(121, MMDC_P1_BASE_ADDR + 0x004, 0x00025576)
MXC_DCD_ITEM(122, MMDC_P0_BASE_ADDR + 0x404, 0x00011006)
MXC_DCD_ITEM(123, MMDC_P1_BASE_ADDR + 0x404, 0x00011006)
MXC_DCD_ITEM(124, MMDC_P0_BASE_ADDR + 0x01c, 0x00000000)
MXC_DCD_ITEM(125, MMDC_P1_BASE_ADDR + 0x01c, 0x00000000)
#else
dcd_hdr:          .word 0x40D802D2 /* Tag=0xD2, Len=90*8 + 4 + 4, Ver=0x40 */
write_dcd_cmd:    .word 0x04D402CC /* Tag=0xCC, Len=90*8 + 4, Param=0x04 */
/* DCD */
MXC_DCD_ITEM(1, IOMUXC_BASE_ADDR + 0x5a8, 0x00000030)
MXC_DCD_ITEM(2, IOMUXC_BASE_ADDR + 0x5b0, 0x00000030)
MXC_DCD_ITEM(3, IOMUXC_BASE_ADDR + 0x524, 0x00000030)
MXC_DCD_ITEM(4, IOMUXC_BASE_ADDR + 0x51c, 0x00000030)
MXC_DCD_ITEM(5, IOMUXC_BASE_ADDR + 0x518, 0x00000030)
MXC_DCD_ITEM(6, IOMUXC_BASE_ADDR + 0x50c, 0x00000030)
MXC_DCD_ITEM(7, IOMUXC_BASE_ADDR + 0x5b8, 0x00000030)
MXC_DCD_ITEM(8, IOMUXC_BASE_ADDR + 0x5c0, 0x00000030)
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x5ac, 0x00020030)
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x5b4, 0x00020030)
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x528, 0x00020030)
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x520, 0x00020030)
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x514, 0x00020030)
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x510, 0x00020030)
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x5bc, 0x00020030)
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x5c4, 0x00020030)
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x56c, 0x00020030)
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x578, 0x00020030)
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x588, 0x00020030)
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x594, 0x00020030)
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x57c, 0x00020030)
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x590, 0x00003000)
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x598, 0x00003000)
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x58c, 0x00000000)
MXC_DCD_ITEM(25, IOMUXC_BASE_ADDR + 0x59c, 0x00003030)
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x5a0, 0x00003030)
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x784, 0x00000030)
MXC_DCD_ITEM(28, IOMUXC_BASE_ADDR + 0x788, 0x00000030)
MXC_DCD_ITEM(29, IOMUXC_BASE_ADDR + 0x794, 0x00000030)
MXC_DCD_ITEM(30, IOMUXC_BASE_ADDR + 0x79c, 0x00000030)
MXC_DCD_ITEM(31, IOMUXC_BASE_ADDR + 0x7a0, 0x00000030)
MXC_DCD_ITEM(32, IOMUXC_BASE_ADDR + 0x7a4, 0x00000030)
MXC_DCD_ITEM(33, IOMUXC_BASE_ADDR + 0x7a8, 0x00000030)
MXC_DCD_ITEM(34, IOMUXC_BASE_ADDR + 0x748, 0x00000030)
MXC_DCD_ITEM(35, IOMUXC_BASE_ADDR + 0x74c, 0x00000030)
MXC_DCD_ITEM(36, IOMUXC_BASE_ADDR + 0x750, 0x00020000)
MXC_DCD_ITEM(37, IOMUXC_BASE_ADDR + 0x758, 0x00000000)
MXC_DCD_ITEM(38, IOMUXC_BASE_ADDR + 0x774, 0x00020000)
MXC_DCD_ITEM(39, IOMUXC_BASE_ADDR + 0x78c, 0x00000030)
MXC_DCD_ITEM(40, IOMUXC_BASE_ADDR + 0x798, 0x000C0000)
MXC_DCD_ITEM(41, MMDC_P0_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(42, MMDC_P0_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(43, MMDC_P0_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(44, MMDC_P0_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(45, MMDC_P1_BASE_ADDR + 0x81c, 0x33333333)
MXC_DCD_ITEM(46, MMDC_P1_BASE_ADDR + 0x820, 0x33333333)
MXC_DCD_ITEM(47, MMDC_P1_BASE_ADDR + 0x824, 0x33333333)
MXC_DCD_ITEM(48, MMDC_P1_BASE_ADDR + 0x828, 0x33333333)
MXC_DCD_ITEM(49, MMDC_P0_BASE_ADDR + 0x018, 0x00081740)
MXC_DCD_ITEM(50, MMDC_P0_BASE_ADDR + 0x01c, 0x00008000)
MXC_DCD_ITEM(51, MMDC_P0_BASE_ADDR + 0x00c, 0x555A7975)
MXC_DCD_ITEM(52, MMDC_P0_BASE_ADDR + 0x010, 0xFF538E64)
MXC_DCD_ITEM(53, MMDC_P0_BASE_ADDR + 0x014, 0x01FF00DB)
MXC_DCD_ITEM(54, MMDC_P0_BASE_ADDR + 0x02c, 0x000026D2)
MXC_DCD_ITEM(55, MMDC_P0_BASE_ADDR + 0x030, 0x005B0E21)
MXC_DCD_ITEM(56, MMDC_P0_BASE_ADDR + 0x008, 0x09444040)
MXC_DCD_ITEM(57, MMDC_P0_BASE_ADDR + 0x004, 0x00025576)
MXC_DCD_ITEM(58, MMDC_P0_BASE_ADDR + 0x040, 0x00000027)
MXC_DCD_ITEM(59, MMDC_P0_BASE_ADDR + 0x000, 0xC31A0000)
MXC_DCD_ITEM(60, MMDC_P0_BASE_ADDR + 0x01c, 0x04088032)
MXC_DCD_ITEM(61, MMDC_P0_BASE_ADDR + 0x01c, 0x0408803A)
MXC_DCD_ITEM(62, MMDC_P0_BASE_ADDR + 0x01c, 0x00008033)
MXC_DCD_ITEM(63, MMDC_P0_BASE_ADDR + 0x01c, 0x0000803B)
MXC_DCD_ITEM(64, MMDC_P0_BASE_ADDR + 0x01c, 0x00428031)
MXC_DCD_ITEM(65, MMDC_P0_BASE_ADDR + 0x01c, 0x00428039)
MXC_DCD_ITEM(66, MMDC_P0_BASE_ADDR + 0x01c, 0x09408030)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x01c, 0x09408038)
MXC_DCD_ITEM(68, MMDC_P0_BASE_ADDR + 0x01c, 0x04008040)
MXC_DCD_ITEM(69, MMDC_P0_BASE_ADDR + 0x01c, 0x04008048)
MXC_DCD_ITEM(70, MMDC_P0_BASE_ADDR + 0x800, 0xA1380003)
MXC_DCD_ITEM(71, MMDC_P1_BASE_ADDR + 0x800, 0xA1380003)
MXC_DCD_ITEM(72, MMDC_P0_BASE_ADDR + 0x020, 0x00005800)
MXC_DCD_ITEM(73, MMDC_P0_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(74, MMDC_P1_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(75, MMDC_P0_BASE_ADDR + 0x83c, 0x434B0350)
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x840, 0x034C0359)
MXC_DCD_ITEM(77, MMDC_P1_BASE_ADDR + 0x83c, 0x434B0350)
MXC_DCD_ITEM(78, MMDC_P1_BASE_ADDR + 0x840, 0x03650348)
MXC_DCD_ITEM(79, MMDC_P0_BASE_ADDR + 0x848, 0x4436383B)
MXC_DCD_ITEM(80, MMDC_P1_BASE_ADDR + 0x848, 0x39393341)
MXC_DCD_ITEM(81, MMDC_P0_BASE_ADDR + 0x850, 0x35373933)
MXC_DCD_ITEM(82, MMDC_P1_BASE_ADDR + 0x850, 0x48254A36)
MXC_DCD_ITEM(83, MMDC_P0_BASE_ADDR + 0x80c, 0x001F001F)
MXC_DCD_ITEM(84, MMDC_P0_BASE_ADDR + 0x810, 0x001F001F)
MXC_DCD_ITEM(85, MMDC_P1_BASE_ADDR + 0x80c, 0x00440044)
MXC_DCD_ITEM(86, MMDC_P1_BASE_ADDR + 0x810, 0x00440044)
MXC_DCD_ITEM(87, MMDC_P0_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(88, MMDC_P1_BASE_ADDR + 0x8b8, 0x00000800)
MXC_DCD_ITEM(89, MMDC_P0_BASE_ADDR + 0x01c, 0x00000000)
MXC_DCD_ITEM(90, MMDC_P0_BASE_ADDR + 0x404, 0x00011006)
#endif
#else
#define ROM_API_TABLE_BASE_ADDR (0x000000C0)
#define ROM_API_HWCNFG_SETUP_OFFSET (0x08)
/*****************PLUGIN IN mode********************/
#ifdef CONFIG_MX6DL_LPDDR2
origin:
  b _start
/* First IVT to copy the plugin that initializes the system into OCRAM */
ivt_header:             .long 0x402000D1    /*Tag=0xD1, Len=0x0020, Ver=0x40 */
app_code_jump_v:        .long IRAM_FREE_START + (plugin_start - origin)    /* Plugin entry point, address after the second IVT table */
reserv1:                .long 0x0
dcd_ptr:                .long 0x0
boot_data_ptr:          .long IRAM_FREE_START + (boot_data - origin) /*0x00907420*/
self_ptr:               .long IRAM_FREE_START + (ivt_header - origin)
app_code_csf:           .long 0x0
reserv2:                .long 0x0
boot_data:              .long IRAM_FREE_START
image_len:              .long 16*1024  /* plugin can be upto 16KB in size */
plugin:                 .long 0x1  /* Enable plugin flag */
/* Second IVT to give entry point into the bootloader copied to DDR */
ivt2_header:            .long 0x402000D1    /*Tag=0xD1, Len=0x0020, Ver=0x40 */
app2_code_jump_v:       .long _start       /* Entry point for uboot */
reserv3:                .long 0x0
dcd2_ptr:               .long 0x0
boot_data2_ptr:         .long boot_data2
self_ptr2:              .long ivt2_header
app_code_csf2:          .long 0x0
reserv4:                .long 0x0
boot_data2:             .long TEXT_BASE
image_len2:             .long _end_of_copy  - TEXT_BASE + CONFIG_FLASH_HEADER_OFFSET
plugin2:                .long 0x0
/* Here starts the plugin code */
plugin_start:
/* Save the return address and the function arguments */
    push    {r0-r4, lr}
* The following is following MX6DL LPDDR2 init script
* "MX6DL_init_LPDDR2_400MHz_1.0.inc"
* With the change of Switch PL301_FAST2 to DDR Dual-channel
* mapping on
/*init script for i.MX6DL LPDDR2*/
/* Revision History*/
/* v1.00 : Init version for Micron MT42L64M64D2KH-18 on CPU LPDDR2 board.
   It's currently soldered, not PoPed.*/
/* Seen passing with overclocking DDR stress test up to 475MHz.*/
/* If someone is playing this init on different DDR device, or on PoPed
   board, please feedback me with result.*/
/* [email protected]*/
/* CCM_BASE_ADDR = 0x020C4000 */
/*DDR clk to 400MHz*/
    ldr r0, =CCM_BASE_ADDR
    ldr r1, =0x00060324
    str r1, [r0, #0x018]
/*IPU2_IPU_CLOCK and IPU1_IPU_CLOCK is necessary for setting
  the Dual-Channel Mode*/
    ldr r1, =0xFFFFFFC3
    str r1, [r0, #0x074]
/* GPV0_BASE_ADDR = 0x00B00000*/
/* Switch PL301_FAST2 to DDR Dual-channel mapping*/
/* Setting This bit to 0x1 will Cause 0x80000000 mapping to Channel 0 and
* 0x10000000 mapping to Channel 1, setting it to 0x0 will only map
* Channel 0 to 0x10000000*/
    ldr r0, =GPV0_BASE_ADDR
    ldr r1, =0x00000001
    str r1, [r0, #0x000]
/* IOMUX*/
/* IOMUXC_BASE_ADDR = 0x020E0000*/
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0*/
    ldr r0, =IOMUXC_BASE_ADDR
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4bc]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4c0]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4c4]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4c8]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS4*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4cc]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS5*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4d0]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS6*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4d4]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS7*/
    ldr r1, =0x00003030
    ldr r1, [r0, #0x4d8]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x470]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x474]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x478]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x47c]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM4*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x480]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM5*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x484]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM6*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x488]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM7*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x48c]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x464]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x490]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x4ac]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_1*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x4b0]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET*/
    ldr r1, =0x00080038
    ldr r1, [r0, #0x494]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCKE0*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x4a4]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCKE1*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x4a8]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be configured using Group Control
   Register: IOMUXC_SW_PAD_CTL_GRP_CTLDS*/
    ldr r1, =0x00000000
    ldr r1, [r0, #0x4a0]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x4b4]
/* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x4b8]
/* IOMUXC_SW_PAD_CTL_GRP_B0DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x764]
/* IOMUXC_SW_PAD_CTL_GRP_B1DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x770]
/* IOMUXC_SW_PAD_CTL_GRP_B2DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x778]
/* IOMUXC_SW_PAD_CTL_GRP_B3DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x77c]
/* IOMUXC_SW_PAD_CTL_GRP_B4DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x780]
/* IOMUXC_SW_PAD_CTL_GRP_B5DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x784]
/* IOMUXC_SW_PAD_CTL_GRP_B6DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x78c]
/* IOMUXC_SW_PAD_CTL_GRP_B7DS*/
    ldr r1, =0x00000030
    ldr r1, [r0, #0x748]
/* IOMUXC_SW_PAD_CTL_GRP_ADDDS*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x74c]
/* IOMUXC_SW_PAD_CTL_GRP_CTLDS*/
    ldr r1, =0x00000038
    ldr r1, [r0, #0x76c]
/* IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL*/
    ldr r1, =0x00020000
    ldr r1, [r0, #0x750]
/* IOMUXC_SW_PAD_CTL_GRP_DDRPKE*/
    ldr r1, =0x00000000
    ldr r1, [r0, #0x754]
/* IOMUXC_SW_PAD_CTL_GRP_DDRMODE*/
    ldr r1, =0x00020000
    ldr r1, [r0, #0x760]
/* IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE*/
    ldr r1, =0x00080000
    ldr r1, [r0, #0x774]
/* DDR Controller Registers*/
/* Manufacturer: Mocron*/
/* Device Part Number: MT42L64M64D2KH-18*/
/* Clock Freq.: 528MHz*/
/* MMDC channels: Both MMDC0, MMDC1*/
/*Density per CS in Gb: 256M*/
/* Chip Selects used: 2*/
/* Number of Banks: 8*/
/* Row address:     14*/
/* Column address: 9*/
/* Data bus width 32*/
/* MMDC_P0_BASE_ADDR = 0x021b0000 */
/* MMDC_P1_BASE_ADDR = 0x021b4000 */
/* MMDC0_MDSCR, set the Configuration request bit during MMDC set up*/
    ldr r0, =MMDC_P0_BASE_ADDR
    ldr r1, =MMDC_P1_BASE_ADDR
    ldr r2, =0x00008000
    str r2, [r0, #0x01c]
/* MMDC1_MDSCR, set the Configuration request bit during MMDC set up*/
    ldr r2, =0x00008000
    str r2, [r1, #0x01c]
/*LPDDR2 ZQ params*/
    ldr r2, =0x1b5f01ff
    str r2, [r0, #0x85c]
    ldr r2, =0x1b5f01ff
    str r2, [r1, #0x85c]
/* Calibration setup.*/
/* DDR_PHY_P0_MPZQHWCTRL, enable on time ZQ calibration*/
    ldr r2, =0xa1390003
    str r2, [r0, #0x800]
/*ca bus abs delay*/
    ldr r2, =0x00400000
    str r2, [r0, #0x890]
    ldr r2, =0x00400000
    str r2, [r1, #0x890]
/* values of 20,40,50,60,7f tried. no difference seen*/
/*frc_msr.*/
    ldr r2, =0x00000800
    str r2, [r0, #0x8b8]
/*frc_msr.*/
    ldr r2, =0x00000800
    str r2, [r1, #0x8b8]
/* DDR_PHY_P0_MPREDQBY0DL3*/
    ldr r2, =0x33333333
    str r2, [r0, #0x81c]
/* DDR_PHY_P0_MPREDQBY1DL3*/
    ldr r2, =0x33333333
    str r2, [r0, #0x820]
/* DDR_PHY_P0_MPREDQBY2DL3*/
    ldr r2, =0x33333333
    str r2, [r0, #0x824]
/* DDR_PHY_P0_MPREDQBY3DL3*/
    ldr r2, =0x33333333
    str r2, [r0, #0x828]
/* DDR_PHY_P1_MPREDQBY0DL3*/
    ldr r2, =0x33333333
    str r2, [r1, #0x81c]
/* DDR_PHY_P1_MPREDQBY1DL3*/
    ldr r2, =0x33333333
    str r2, [r1, #0x820]
/* DDR_PHY_P1_MPREDQBY2DL3*/
    ldr r2, =0x33333333
    str r2, [r1, #0x824]
/* DDR_PHY_P1_MPREDQBY3DL3*/
    ldr r2, =0x33333333
    str r2, [r1, #0x828]
/*write delayes:*/
/*setmem /32 0x021b082c = 0xf3333333 all byte 0 data & dm delayed by 3*/
/*all byte 1 data & dm delayed by 3*/
    ldr r2, =0xf3333333
    str r2, [r0, #0x830]
/*all byte 2 data & dm delayed by 3*/
    ldr r2, =0xf3333333
    str r2, [r0, #0x834]
/*all byte 3 data & dm delayed by 3*/
    ldr r2, =0xf3333333
    str r2, [r0, #0x838]
/*all byte 0 data & dm delayed by 3*/
    ldr r2, =0xf3333333
    str r2, [r1, #0x82c]
    ldr r2, =0xf3333333
    str r2, [r1, #0x830]
    ldr r2, =0xf3333333
    str r2, [r1, #0x834]
    ldr r2, =0xf3333333
    str r2, [r1, #0x838]
/* Read and write data delay, per byte.*/
/* For optimized DDR operation it is recommended to run mmdc_calibration on
   your board, and replace 4 delay register assigns with resulted values*/
/* Note:*/
/* a. DQS gating is not relevant for LPDDR2. DSQ gating calibration section
   will stall*/
/* b. The calibration code that runs for both MMDC0 & MMDC1 should be used.*/
/*it is strongly recommended to run calibration on your board, and replace
  bellow values:*/
/*Read calibration*/
    ldr r2, =0x444A4F4D
    str r2, [r0, #0x848]
    ldr r2, =0x4B4E4042
    str r2, [r1, #0x848]
/*Write calibration*/
    ldr r2, =0x312E272E
    str r2, [r0, #0x850]
    ldr r2, =0x28302E2B
    str r2, [r1, #0x850]
/*dqs gating dis*/
    ldr r2, =0x20000000
    str r2, [r0, #0x83c]
    ldr r2, =0x0
    str r2, [r0, #0x840]
    ldr r2, =0x20000000
    str r2, [r1, #0x83c]
    ldr r2, =0x0
    str r2, [r1, #0x840]
/*setmem /32 0x021b0858 = 0xa00 clk delay*/
/*setmem /32 0x021b4858 = 0xa00 clk delay*/
/*frc_msr*/
    ldr r2, =0x00000800
/*frc_msr*/
    ldr r2, =0x00000800
/* Calibration setup end*/
/* Channel0 - startng address 0x80000000*/
/* MMDC0_MDCFG0*/
    ldr r2, =0x3f436133
    str r2, [r0, #0x00c]
/* MMDC0_MDPDC*/
    ldr r2, =0x00020024
    str r2, [r0, #0x004]
/* MMDC0_MDCFG1*/
    ldr r2, =0x00100A82
    str r2, [r0, #0x010]
/* MMDC0_MDCFG2*/
    ldr r2, =0x00000093
    str r2, [r0, #0x014]
/* MMDC0_MDMISC*/
    ldr r2, =0x0000174C
    str r2, [r0, #0x018]
/* MMDC0_MDRWD;*/
    ldr r2, =0x0f9f26d2
    str r2, [r0, #0x02c]
/* MMDC0_MDOR*/
    ldr r2, =0x0000020e
    str r2, [r0, #0x030]
/* MMDC0_MDCFG3LP*/
    ldr r2, =0x001a099a
    str r2, [r0, #0x038]
/* MMDC0_MDOTC*/
    ldr r2, =0x00000000
    str r2, [r0, #0x008]
/* CS0_END*/
    ldr r2, =0x0000005f
    str r2, [r0, #0x040]
/* ROC*/
    ldr r2, =0x0000000f
    str r2, [r0, #0x404]
/* MMDC0_MDCTL*/
    ldr r2, =0xc3010000
    str r2, [r0, #0x000]
/* Channel1 - starting address 0x10000000*/
/* MMDC1_MDCFG0*/
    ldr r2, =0x3f436133
    str r2, [r1, #0x00c]
/* MMDC1_MDPDC*/
    ldr r2, =0x00020024
    str r2, [r1, #0x004]
/* MMDC1_MDCFG1*/
    ldr r2, =0x00100A82
    str r2, [r1, #0x010]
/* MMDC1_MDCFG2*/
    ldr r2, =0x00000093
    str r2, [r1, #0x014]
/* MMDC1_MDMISC*/
    ldr r2, =0x0000174C
    str r2, [r1, #0x018]
/* MMDC1_MDRWD;*/
    ldr r2, =0x0f9f26d2
    str r2, [r1, #0x02c]
/* MMDC1_MDOR*/
    ldr r2, =0x0000020e
    str r2, [r1, #0x030]
/* MMDC1_MDCFG3LP*/
    ldr r2, =0x001a099a
    str r2, [r1, #0x038]
/* MMDC1_MDOTC*/
    ldr r2, =0x00000000
    str r2, [r1, #0x008]
/* CS0_END*/
    ldr r2, =0x0000003f
    str r2, [r1, #0x040]
/* MMDC1_MDCTL*/
    ldr r2, =0xc3010000
    str r2, [r1, #0x000]
/* MRW: BA=0 CS=0 MR_ADDR=63 MR_OP=0*/
    ldr r2, =0x003f8030
/* MRW: BA=0 CS=0 MR_ADDR=10 MR_OP=ff*/
    ldr r2, =0xff0a8030
/* MRW: BA=0 CS=0 MR_ADDR=1  MR_OP=c2*/
    ldr r2, =0xc2018030
/* MRW: BA=0 CS=0 MR_ADDR=2  MR_OP=4. tcl=6, tcwl=3*/
    ldr r2, =0x04028030
/* MRW: BA=0 CS=0 MR_ADDR=3  MR_OP=2.drive=240/6*/
    ldr r2, =0x02038030
    ldr r2, =0x003f8030
    ldr r2, =0xff0a8030
    ldr r2, =0xc2018030
    ldr r2, =0x04028030
    ldr r2, =0x02038030
/* MMDC0_MDREF*/
    ldr r2, =0x00005800
    str r2, [r0, #0x020]
/* MMDC1_MDREF*/
    ldr r2, =0x00005800
    str r2, [r1, #0x020]
/* DDR_PHY_P0_MPODTCTRL*/
    ldr r2, =0x00000000
    str r2, [r0, #0x818]
/* DDR_PHY_P1_MPODTCTRL*/
    ldr r2, =0x00000000
    str r2, [r1, #0x818]
/*calibration values based on calibration compare of 0x00ffff00:*/
/*Note, these calibration values are based on Freescale's board*/
/*May need to run calibration on target board to fine tune these*/
/* DDR_PHY_P0_MPZQHWCTRL, enable automatic ZQ calibration*/
    ldr r2, =0xa1310003
/* DDR_PHY_P0_MPMUR0, frc_msr*/
    ldr r2, =0x00000800
/* DDR_PHY_P1_MPMUR0, frc_msr*/
    ldr r2, =0x00000800
/* MMDC0_MDSCR, clear this register (especially the configuration
   bit as initialization is complete)*/
    ldr r2, =0x00000000
    ldr r2, =0x00000000
    ldr r2, =0x00000800
    ldr r2, =0x00000800
* End of LPDDR init script
    The following is to fill in those arguments for this ROM function
    pu_irom_hwcnfg_setup(void **start, size_t *bytes, const void *boot_data)
    This function is used to copy data from the storage media into DDR.
    start - Initial (possibly partial) image load address on entry.  Final
    image load address on exit.
    bytes - Initial (possibly partial) image size on entry.  Final image size
    on exit.
    boot_data - Initial @ref ivt Boot Data load address.
    adr r0, DDR_DEST_ADDR
    adr r1, COPY_SIZE
    adr r2, BOOT_DATA
* check the _pu_irom_api_table for the address
* pu_irom_hwcnfg_setup is in 0x1fb5  ERIC : < what is the address in Rigel >
before_calling_rom___pu_irom_hwcnfg_setup:
    ldr r3, =ROM_API_TABLE_BASE_ADDR
    ldr r4, [r3, #ROM_API_HWCNFG_SETUP_OFFSET]
    blx r4
after_calling_rom___pu_irom_hwcnfg_setup:
/* To return to ROM from plugin, we need to fill in these argument.
* Here is what need to do:
* Need to construct the paramters for this function before return to ROM:
* plugin_download(void **start, size_t *bytes, UINT32 *ivt_offset)
    pop {r0-r4, lr}
    ldr r5, DDR_DEST_ADDR
    str r5, [r0]
    ldr r5, COPY_SIZE
    str r5, [r1]
    mov r5, #0x400  /* Point to the second IVT table at offset 0x42C */
    add r5, r5, #0x2C
    str r5, [r2]
    mov r0, #1
    bx lr          /* return back to ROM code */
DDR_DEST_ADDR:    .word   TEXT_BASE
COPY_SIZE:        .word   _end_of_copy  - TEXT_BASE + CONFIG_FLASH_HEADER_OFFSET
BOOT_DATA:        .word   TEXT_BASE
                  .word   0
#else
/*DDR clock:480MHz, ipg clock:40MHz, AHB clock:80MHz*/
#define CONFIG_IPG_40M_FR_PLL3
  b _start
app_code_jump_v:        .long 0x00907458    /* Plugin entry point, address after the second IVT table */
reserv1:                .long 0x0
dcd_ptr:                .long 0x0
boot_data_ptr:          .long 0x00907420
self_ptr:               .long 0x00907400
reserv2:                .long 0x0
boot_data:              .long 0x00907000
reserv3:                .long 0x0
dcd2_ptr:               .long 0x0
reserv4:                .long 0x0
plugin2:                .long 0x0
plugin_start:
    push    {r0-r4, lr}
* Note: The DDR settings provided below are specific to Freescale development boards and are the latest settings at the time of release.
* However, it is recommended to contact your Freescale representative in case there are any improvements to these settings.
#ifdef CONFIG_IPG_40M_FR_PLL3
    /*select pll3 for ipg clk 40M */
    ldr r1, [r0,#0x14]
    ldr r2, =0x2000000
    orr r1, r1, r2
    ldr r2, =0x1c00
    bic r1, r2
    ldr r2, =0x1400
    orr r1, r1, r2
    str r1, [r0,#0x14]
    /*enable pll3 */
    ldr r0, =ANATOP_BASE_ADDR
    ldr r1, =0x10000
    str r1, [r0,#0x28]
    ldr r1, =0x3040
    str r1, [r0,#0x24]
#endif
    /* Init the DDR according the init script */
    /* select 528MHz for pre_periph_clk_sel */
    ldr r1, =0x00020324
    str r1, [r0,#0x18]
    /* IOMUX setting */
    mov r1, #0x30
    str r1, [r0,#0x5a8]
    str r1, [r0,#0x5b0]
    str r1, [r0,#0x524]
    str r1, [r0,#0x51c]
    str r1, [r0,#0x518]
    str r1, [r0,#0x50c]
    str r1, [r0,#0x5b8]
    str r1, [r0,#0x5c0]
    ldr r1, =0x00020030
    str r1, [r0,#0x5ac]
    str r1, [r0,#0x5b4]
    str r1, [r0,#0x528]
    str r1, [r0,#0x520]
    str r1, [r0,#0x514]
    str r1, [r0,#0x510]
    str r1, [r0,#0x5bc]
    str r1, [r0,#0x5c4]
    str r1, [r0,#0x56c]
    str r1, [r0,#0x578]
    str r1, [r0,#0x588]
    str r1, [r0,#0x594]
    str r1, [r0,#0x57c]
    ldr r1, =0x00003000
    str r1, [r0,#0x590]
    str r1, [r0,#0x598]
    mov r1, #0x00000000
    str r1, [r0,#0x58c]
    ldr r1, =0x00003030
    str r1, [r0,#0x59c]
    str r1, [r0,#0x5a0]
    ldr r1, =0x00000030
    str r1, [r0,#0x784]
    str r1, [r0,#0x788]
    str r1, [r0,#0x794]
    str r1, [r0,#0x79c]
    str r1, [r0,#0x7a0]
    str r1, [r0,#0x7a4]
    str r1, [r0,#0x7a8]
    str r1, [r0,#0x748]
    str r1, [r0,#0x74c]
    mov r1, #0x00020000
    str r1, [r0,#0x750]
    mov r1, #0x00000000
    str r1, [r0,#0x758]
    mov r1, #0x00020000
    str r1, [r0,#0x774]
    mov r1, #0x30
    str r1, [r0,#0x78c]
    mov r1, #0x000c0000
    str r1, [r0,#0x798]
    /* Initialize 2GB DDR3 - Micron MT41J128M */
    ldr r2, =MMDC_P1_BASE_ADDR
    ldr r1, =0x33333333
    str r1, [r0,#0x81c]
    str r1, [r0,#0x820]
    str r1, [r0,#0x824]
    str r1, [r0,#0x828]
    str r1, [r2,#0x81c]
    str r1, [r2,#0x820]
    str r1, [r2,#0x824]
    str r1, [r2,#0x828]
    ldr r1, =0x00081740
    str r1, [r0,#0x18]
    ldr r1, =0x00008000
    str r1, [r0,#0x1c]
    ldr r1, =0x555a7975
    str r1, [r0,#0x0c]
    ldr r1, =0xff538e64
    str r1, [r0,#0x10]
    ldr r1, =0x01ff00db
    str r1, [r0,#0x14]
    ldr r1, =0x000026d2
    str r1, [r0,#0x2c]
    ldr r1, =0x005b0e21
    str r1, [r0,#0x30]
    ldr r1, =0x94444040
    str r1, [r0,#0x08]
    ldr r1, =0x00020036
    str r1, [r0,#0x04]
    ldr r1, =0x00000027
    str r1, [r0,#0x40]
    ldr r1, =0xc31a0000
    str r1, [r0,#0x00]
    ldr r1, =0x04088032
    str r1, [r0,#0x1c]
    ldr r1, =0x0408803a
    str r1, [r0,#0x1c]
    ldr r1, =0x00008033
    str r1, [r0,#0x1c]
    ldr r1, =0x0000803b
    str r1, [r0,#0x1c]
    ldr r1, =0x00428031
    str r1, [r0,#0x1c]
    ldr r1, =0x00428039
    str r1, [r0,#0x1c]
    ldr r1, =0x09408030
    str r1, [r0,#0x1c]
    ldr r1, =0x09408038
    str r1, [r0,#0x1c]
    ldr r1, =0x04008040
    str r1, [r0,#0x1c]
    ldr r1, =0x04008048
    str r1, [r0,#0x1c]
    ldr r1, =0xa5380003
    str r1, [r0,#0x800]
    ldr r1, =0xa5380003
    str r1, [r2,#0x800]
    ldr r1, =0x00005800
    str r1, [r0,#0x20]
    ldr r1, =0x00000007
    str r1, [r0,#0x818]
    ldr r1, =0x00000007
    str r1, [r2,#0x818]
    ldr r1, =0x433f033f
    str r1, [r0,#0x83c]
    ldr r1, =0x033f033f
    str r1, [r0,#0x840]
    ldr r1, =0x433f033f
    str r1, [r2,#0x83c]
    ldr r1, =0x0344033b
    str r1, [r2,#0x840]
    ldr r1, =0x4337373e
    str r1, [r0,#0x848]
    ldr r1, =0x3634303d
    str r1, [r2,#0x848]
    ldr r1, =0x35374640
    str r1, [r0,#0x850]
    ldr r1, =0x4a294b35
    str r1, [r2,#0x850]
    ldr r1, =0x001F001F
    str r1, [r0,#0x80c]
    ldr r1, =0x001F001F
    str r1, [r0,#0x810]
    ldr r1, =0x00440044
    str r1, [r2,#0x80c]
    ldr r1, =0x00440044
    str r1, [r2,#0x810]
    ldr r1, =0x00000800
    str r1, [r0,#0x8b8]
    ldr r1, =0x00000800
    str r1, [r2,#0x8b8]
    ldr r1, =0x00000000
    str r1, [r0,#0x1c]
    start - Initial (possibly partial) image load address on entry.  Final image load address on exit.
    bytes - Initial (possibly partial) image size on entry.  Final image size on exit.
    adr r1, COPY_SIZE
    adr r2, BOOT_DATA
    blx r4
    pop {r0-r4, lr}
    str r5, [r0]
    ldr r5, COPY_SIZE
    str r5, [r1]
    add r5, r5, #0x2C
    str r5, [r2]
    mov r0, #1
                  .word   0
#endif
#endif
#endif
13 回复数
11,649 次查看
AnsonHuang
Hi, Yamil
#include <config.h>
#endif
dcd_node_##i:                        \
  b _start
reserv1:          .word 0x0
#else
#endif
reserv2:          .word 0x0
#else
#endif
plugin:           .word 0x0
# DDR IO TYPE
# Clock
# Address
# Control
# Data Strobe
# DATA
# Calibrations
# ZQ
# write leveling
# MMDC init:
#else
#endif
# MR2
# MR3
# MR1
# MR0
# ZQ calibration
# final DDR setup
# IOMUX SETTINGS
* Row address:     14
* Column address: 9
* Data bus width 32
/*frc_msr.*/
/*frc_msr.*/
* Note:
*    will stall
/*dqs gating dis */
/*clk delay */
/*clk delay */
/*frc_msr */
/*frc_msr */
/* MMDC0_MDCFG0 */
/* MMDC0_MDPDC */
/* MMDC0_MDCFG1 */
/* MMDC0_MDCFG2 */
/* MMDC0_MDMISC */
/* MMDC0_MDRWD;*/
/* MMDC0_MDOR */
/* MMDC0_MDOTC */
/* CS0_END */
/* ROC */
/* MMDC0_MDCTL */
/* MMDC1_MDCFG0 */
/* MMDC1_MDPDC */
/* MMDC1_MDCFG1 */
/* MMDC1_MDCFG2 */
/* MMDC1_MDMISC */
/* MMDC1_MDRWD;*/
/* MMDC1_MDOR */
/* MMDC1_MDOTC */
/* CS0_END */
/* MMDC1_MDCTL */
/* MMDC0_MDREF */
/* MMDC1_MDREF */
/* DCD */
#else
/* DCD */
#endif
#else
origin:
  b _start
reserv1:                .long 0x0
dcd_ptr:                .long 0x0
reserv2:                .long 0x0
reserv3:                .long 0x0
dcd2_ptr:               .long 0x0
reserv4:                .long 0x0
plugin2:                .long 0x0
plugin_start:
    push    {r0-r4, lr}
* mapping on
    ldr r1, =0x00060324
    ldr r1, =0xFFFFFFC3
    ldr r1, =0x00000001
/* IOMUX*/
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00003030
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00080038
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000000
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000030
    ldr r1, =0x00000038
    ldr r1, =0x00000038
    ldr r1, =0x00020000
    ldr r1, =0x00000000
    ldr r1, =0x00020000
    ldr r1, =0x00080000
    ldr r2, =0x00008000
    ldr r2, =0x00008000
    ldr r2, =0x1b5f01ff
    ldr r2, =0x1b5f01ff
    ldr r2, =0xa1390003
    ldr r2, =0x00400000
    ldr r2, =0x00400000
/*frc_msr.*/
    ldr r2, =0x00000800
/*frc_msr.*/
    ldr r2, =0x00000800
    ldr r2, =0x33333333
    ldr r2, =0x33333333
    ldr r2, =0x33333333
    ldr r2, =0x33333333
    ldr r2, =0x33333333
    ldr r2, =0x33333333
    ldr r2, =0x33333333
    ldr r2, =0x33333333
/*write delayes:*/
    ldr r2, =0xf3333333
    ldr r2, =0xf3333333
    ldr r2, =0xf3333333
    ldr r2, =0xf3333333
    ldr r2, =0xf3333333
    ldr r2, =0xf3333333
    ldr r2, =0xf3333333
/* Note:*/
   will stall*/
  bellow values:*/
    ldr r2, =0x444A4F4D
    ldr r2, =0x4B4E4042
    ldr r2, =0x312E272E
    ldr r2, =0x28302E2B
/*dqs gating dis*/
    ldr r2, =0x20000000
    ldr r2, =0x0
    ldr r2, =0x20000000
    ldr r2, =0x0
/*frc_msr*/
    ldr r2, =0x00000800
/*frc_msr*/
    ldr r2, =0x00000800
/* MMDC0_MDCFG0*/
    ldr r2, =0x3f436133
/* MMDC0_MDPDC*/
    ldr r2, =0x00020024
/* MMDC0_MDCFG1*/
    ldr r2, =0x00100A82
/* MMDC0_MDCFG2*/
    ldr r2, =0x00000093
/* MMDC0_MDMISC*/
    ldr r2, =0x0000174C
/* MMDC0_MDRWD;*/
    ldr r2, =0x0f9f26d2
/* MMDC0_MDOR*/
    ldr r2, =0x0000020e
/* MMDC0_MDCFG3LP*/
    ldr r2, =0x001a099a
/* MMDC0_MDOTC*/
    ldr r2, =0x00000000
/* CS0_END*/
    ldr r2, =0x0000005f
/* ROC*/
    ldr r2, =0x0000000f
/* MMDC0_MDCTL*/
    ldr r2, =0xc3010000
/* MMDC1_MDCFG0*/
    ldr r2, =0x3f436133
/* MMDC1_MDPDC*/
    ldr r2, =0x00020024
/* MMDC1_MDCFG1*/
    ldr r2, =0x00100A82
/* MMDC1_MDCFG2*/
    ldr r2, =0x00000093
/* MMDC1_MDMISC*/
    ldr r2, =0x0000174C
/* MMDC1_MDRWD;*/
    ldr r2, =0x0f9f26d2
/* MMDC1_MDOR*/
    ldr r2, =0x0000020e
/* MMDC1_MDCFG3LP*/
    ldr r2, =0x001a099a
/* MMDC1_MDOTC*/
    ldr r2, =0x00000000
/* CS0_END*/
    ldr r2, =0x0000003f
/* MMDC1_MDCTL*/
    ldr r2, =0xc3010000
    ldr r2, =0x003f8030
    ldr r2, =0xff0a8030
    ldr r2, =0xc2018030
    ldr r2, =0x04028030
    ldr r2, =0x02038030
    ldr r2, =0x003f8030
    ldr r2, =0xff0a8030
    ldr r2, =0xc2018030
    ldr r2, =0x04028030
    ldr r2, =0x02038030
/* MMDC0_MDREF*/
    ldr r2, =0x00005800
/* MMDC1_MDREF*/
    ldr r2, =0x00005800
    ldr r2, =0x00000000
    ldr r2, =0x00000000
    ldr r2, =0xa1310003
    ldr r2, =0x00000800
    ldr r2, =0x00000800
    ldr r2, =0x00000000
    ldr r2, =0x00000000
    ldr r2, =0x00000800
    ldr r2, =0x00000800
    on exit.
    adr r1, COPY_SIZE
    adr r2, BOOT_DATA
    blx r4
    pop {r0-r4, lr}
    str r5, [r0]
    ldr r5, COPY_SIZE
    str r5, [r1]
    add r5, r5, #0x2C
    str r5, [r2]
    mov r0, #1
                  .word   0
#else
  b _start
reserv1:                .long 0x0
dcd_ptr:                .long 0x0
reserv2:                .long 0x0
reserv3:                .long 0x0
dcd2_ptr:               .long 0x0
reserv4:                .long 0x0
plugin2:                .long 0x0
plugin_start:
    push    {r0-r4, lr}
    ldr r1, [r0,#0x14]
    ldr r2, =0x2000000
    orr r1, r1, r2
    ldr r2, =0x1c00
    bic r1, r2
    ldr r2, =0x1400
    orr r1, r1, r2
    str r1, [r0,#0x14]
    /*enable pll3 */
    ldr r1, =0x10000
    str r1, [r0,#0x28]
    ldr r1, =0x3040
    str r1, [r0,#0x24]
#endif
    ldr r1, =0x00020324
    str r1, [r0,#0x18]
    /* IOMUX setting */
    mov r1, #0x30
    str r1, [r0,#0x5a8]
    str r1, [r0,#0x5b0]
    str r1, [r0,#0x524]
    str r1, [r0,#0x51c]
    str r1, [r0,#0x518]
    str r1, [r0,#0x50c]
    str r1, [r0,#0x5b8]
    str r1, [r0,#0x5c0]
    ldr r1, =0x00020030
    str r1, [r0,#0x5ac]
    str r1, [r0,#0x5b4]
    str r1, [r0,#0x528]
    str r1, [r0,#0x520]
    str r1, [r0,#0x514]
    str r1, [r0,#0x510]
    str r1, [r0,#0x5bc]
    str r1, [r0,#0x5c4]
    str r1, [r0,#0x56c]
    str r1, [r0,#0x578]
    str r1, [r0,#0x588]
    str r1, [r0,#0x594]
    str r1, [r0,#0x57c]
    ldr r1, =0x00003000
    str r1, [r0,#0x590]
    str r1, [r0,#0x598]
    mov r1, #0x00000000
    str r1, [r0,#0x58c]
    ldr r1, =0x00003030
    str r1, [r0,#0x59c]
    str r1, [r0,#0x5a0]
    ldr r1, =0x00000030
    str r1, [r0,#0x784]
    str r1, [r0,#0x788]
    str r1, [r0,#0x794]
    str r1, [r0,#0x79c]
    str r1, [r0,#0x7a0]
    str r1, [r0,#0x7a4]
    str r1, [r0,#0x7a8]
    str r1, [r0,#0x748]
    str r1, [r0,#0x74c]
    mov r1, #0x00020000
    str r1, [r0,#0x750]
    mov r1, #0x00000000
    str r1, [r0,#0x758]
    mov r1, #0x00020000
    str r1, [r0,#0x774]
    mov r1, #0x30
    str r1, [r0,#0x78c]
    mov r1, #0x000c0000
    str r1, [r0,#0x798]
    ldr r1, =0x33333333
    str r1, [r0,#0x81c]
    str r1, [r0,#0x820]
    str r1, [r0,#0x824]
    str r1, [r0,#0x828]
    str r1, [r2,#0x81c]
    str r1, [r2,#0x820]
    str r1, [r2,#0x824]
    str r1, [r2,#0x828]
    ldr r1, =0x00081740
    str r1, [r0,#0x18]
    ldr r1, =0x00008000
    str r1, [r0,#0x1c]
    ldr r1, =0x555a7975
    str r1, [r0,#0x0c]
    ldr r1, =0xff538e64
    str r1, [r0,#0x10]
    ldr r1, =0x01ff00db
    str r1, [r0,#0x14]
    ldr r1, =0x000026d2
    str r1, [r0,#0x2c]
    ldr r1, =0x005b0e21
    str r1, [r0,#0x30]
    ldr r1, =0x94444040
    str r1, [r0,#0x08]
    ldr r1, =0x00020036
    str r1, [r0,#0x04]
    ldr r1, =0x00000027
    str r1, [r0,#0x40]
    ldr r1, =0xc31a0000
    str r1, [r0,#0x00]
    ldr r1, =0x04088032
    str r1, [r0,#0x1c]
    ldr r1, =0x0408803a
    str r1, [r0,#0x1c]
    ldr r1, =0x00008033
    str r1, [r0,#0x1c]
    ldr r1, =0x0000803b
    str r1, [r0,#0x1c]
    ldr r1, =0x00428031
    str r1, [r0,#0x1c]
    ldr r1, =0x00428039
    str r1, [r0,#0x1c]
    ldr r1, =0x09408030
    str r1, [r0,#0x1c]
    ldr r1, =0x09408038
    str r1, [r0,#0x1c]
    ldr r1, =0x04008040
    str r1, [r0,#0x1c]
    ldr r1, =0x04008048
    str r1, [r0,#0x1c]
    ldr r1, =0xa5380003
    str r1, [r0,#0x800]
    ldr r1, =0xa5380003
    str r1, [r2,#0x800]
    ldr r1, =0x00005800
    str r1, [r0,#0x20]
    ldr r1, =0x00000007
    str r1, [r0,#0x818]
    ldr r1, =0x00000007
    str r1, [r2,#0x818]
    ldr r1, =0x433f033f
    str r1, [r0,#0x83c]
    ldr r1, =0x033f033f
    str r1, [r0,#0x840]
    ldr r1, =0x433f033f
    str r1, [r2,#0x83c]
    ldr r1, =0x0344033b
    str r1, [r2,#0x840]
    ldr r1, =0x4337373e
    str r1, [r0,#0x848]
    ldr r1, =0x3634303d
    str r1, [r2,#0x848]
    ldr r1, =0x35374640
    str r1, [r0,#0x850]
    ldr r1, =0x4a294b35
    str r1, [r2,#0x850]
    ldr r1, =0x001F001F
    str r1, [r0,#0x80c]
    ldr r1, =0x001F001F
    str r1, [r0,#0x810]
    ldr r1, =0x00440044
    str r1, [r2,#0x80c]
    ldr r1, =0x00440044
    str r1, [r2,#0x810]
    ldr r1, =0x00000800
    str r1, [r0,#0x8b8]
    ldr r1, =0x00000800
    str r1, [r2,#0x8b8]
    ldr r1, =0x00000000
    str r1, [r0,#0x1c]
    adr r1, COPY_SIZE
    adr r2, BOOT_DATA
    blx r4
    pop {r0-r4, lr}
    str r5, [r0]
    ldr r5, COPY_SIZE
    str r5, [r1]
    add r5, r5, #0x2C
    str r5, [r2]
    mov r0, #1
                  .word   0
#endif
#endif
#endif
11,648 次查看
oferfederovsky
Hi Yongcai,
Have you (or anyone else) managed to make LPDDR2 to work with 528MHz on the ARM2 (or similar)?
Thanks.
11,648 次查看
AnsonHuang
No, I guess you only need to config the MMDC clock and apply 528M LPDDR2 script to make it work at 528MHz.
11,648 次查看
oferfederovsky
Thanks for the reply.
We didn't manage to use the script to make it work (I guess you are talking about this excel tool: i.Mx6DQSDL LPDDR2 Script Aid).
However, we do have a fully working setup for our custom board, with 400MHz.
This is our setup:
  • i.mx6q AC (MCIMX6Q5EYM10AC)
  • LPDDR2: SAMSUNG 4Gb(128M x32) LPDDR2-S4 SDRAM + 4Gb(128M x32) LPDDR2-S4 SDRAM 216FBGA, 12x12 (K3PE7E70QM-BGC2)
From the calibration tool:
    DDR Stress Test (1.0.2) for MX6DQ
    Build: Dec 10 2013, 12:31:54
    Freescale Semiconductor, Inc.
=======DDR configuration==========
BOOT_CFG3[5-4]: 0x00, Single DDR channel.
DDR type is LPDDR2 in 1-channel mode.
Data width: 64, bank num: 8
Row size: 14, col size: 10
Chip select CSD0 is used
Density per chip select: 1024MB
Here is the working DCD values (for 400MHz):
/* DCD */
/* 400MHz */
// SDQS0..7
// DQM0..7
// CAS
// RAS
// SDCLK_0
// SDCLK_1
// RESET
// SDCKE0
// SDCKE1
// SDBA2
// SDODT0
// SDODT1
// GRP_B0..7DS
// GRP_ADDDS
// GRP_DDRMODE_CTL
// GRP_DDRPKE
// GRP_DDRMODE
// GRP_CTLDS
// GRP_DDR_TYPE
// MMDC/DDR read delay calibration
// MXC_DCD_ITEM(126, MMDC_P0_BASE_ADDR + 0x860, 0x10)
// MMDC/DDR Write delay calibration
// MXC_DCD_ITEM(127, MMDC_P0_BASE_ADDR + 0x864, 0x10)
// MDSCR
// MPZQLP2CTL
// MPZQHWCTRL
// MPPDCMPR2
// MPWRCADL
// MPMUR0
// MPRDDQBY0..3DL
// MPWRDQBY0..3DL
// MPRDDLCTL, MPWRDLCTL
MXC_DCD_ITEM(69, MMDC_P0_BASE_ADDR + 0x848, 0x3e36383c)
MXC_DCD_ITEM(70, MMDC_P0_BASE_ADDR + 0x850, 0x32363432)
MXC_DCD_ITEM(71, MMDC_P1_BASE_ADDR + 0x848, 0x3c3c3a42)
MXC_DCD_ITEM(72, MMDC_P1_BASE_ADDR + 0x850, 0x3a2e3c36)
// MPDGCTL0..1
// MPSDCTRL
// MPMUR0 (second time?)
// MDCFG0, MDPDC, MDCFG1, MDCFG2, MDMISC, MDRWD, MDOR, MDCFG3LP, MDOTC, MDASP, MDCTL
MXC_DCD_ITEM(90, MMDC_P0_BASE_ADDR + 0x40, 0x27) // was 0x5f
MXC_DCD_ITEM(91, MMDC_P0_BASE_ADDR + 0x0, 0x83120000)
MXC_DCD_ITEM(101, MMDC_P1_BASE_ADDR + 0x40, 0x17) // was 0x3f
MXC_DCD_ITEM(102, MMDC_P1_BASE_ADDR + 0x0, 0x83120000)
// MDSCR*5
// MDSCR*5
// MPZQHWCTRL (second time?)
// MDREF
// MDODTCTRL
// MPZQHWCTRL (third time?)
// MDSCR (again)
// MAPSR
We are trying to switch to 528MHz, but keep failing.
Can you tell us which values to modify?
Thanks!
Ofer
11,647 次查看
Yuri
The enclosed may be helpful.
11,647 次查看
oferfederovsky
Hello Yuri,
Do you know by fact that what you sent us actually works?
Can you tell us on which hardware? was it on evaluation board?
And please, in which mode does it work (BOOT_CFG[5:4])?
Thanks!
Ofer
11,647 次查看
Yuri
Also one can vary DDR_SEL options. Basically DDR_SEL (say, in IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE
register) is intended to adjust drive strength, which is mainly configured via DSE field.
11,647 次查看
oferfederovsky
Thanks for the reply, but we are still struggling with the LPDDR2 in 528MHz.
We did manage to complete boot-up in 528MHz, but the system is unstable:
  * We have some failures when running memory tests.
    * According to the test results, the failures are in 1 or 2 single bits of the data.
  * We have some random segmentation faults in user processes.
What we did to get us this far:
* We started with our 400MHz setup (listed above).
* We changed the freq to 528MHz by: MXC_DCD_ITEM(1, CCM_BASE_ADDR + 0x18, 0x20324)
* Calibration (using freescale tool)
  * The tool failed to complete the calibration.
  * We played with register MMDC Duty Cycle Control Register (MMDC1_MPDCCR):
    * MXC_DCD_ITEM(65, MMDC_P0_BASE_ADDR + 0x8c0, 0x24911492)
    * MXC_DCD_ITEM(65, MMDC_P1_BASE_ADDR + 0x8c0, 0x24911492)
  * Now, the calibration tool ran successfully, and we used the calibration results in our u-boot.
* At this point we noticed that suspend/resume stopped working for us.
  * Once going into suspend, we got hang.
* To overcome this, we played with register MMDC PHY ZQ HW control register (MMDCx_MPZQHWCTRL),
  which for some reason we had it written 3 times (per channel):
  1) MXC_DCD_ITEM(46, MMDC_P0_BASE_ADDR + 0x800, 0xa1390000)
  2) MXC_DCD_ITEM(115, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003)
    MXC_DCD_ITEM(116, MMDC_P1_BASE_ADDR + 0x800, 0xa1390003)
  3) MXC_DCD_ITEM(121, MMDC_P0_BASE_ADDR + 0x800, 0xa1390003) // Causes problems - suspend / resume
    MXC_DCD_ITEM(122, MMDC_P1_BASE_ADDR + 0x800, 0xa1390003) // Causes problems - suspend / resume
  * Removing the (redundant?) 3'rd write, for some reason, fixed this suspend/resume issue.
So, now we still need to overcome the stability issue.
We noticed, that we have more failures when the temperature changes.
We tried to play with the IOMUX OTD values and the termination values of the pads, but we didn't see any influence.
We tried to boot from both sd-card and NOR, but we didn't notice any difference.
Attached is our current configuration.
Any help is most appreciated.
Thanks!
Ofer
11,647 次查看
Yuri
Is it possible to try DDR_INPUT bit of IOMUXC_SW_PAD_CTL_PAD_DRAM_xxx registers as “1”.
(Differential input mode)  ?
https://community.freescale.com/message/409137#409137
2.
DSE filed of DRAM signals (0x38) is set for maximum driving strength – is this reasonable ?
Did the customer use different DSE options ?
11,647 次查看
oferfederovsky
1. Following your reply, I tried to use differential input mode, but the results were worse.
2. We tried several values for drive-strength and on-die-termination
    We didn't notice any change when using different on-die termination values.
    We didn't notice any difference when using 34Ohm or 40Ohm in drive-strength field.
          The results with other values were worse.
Are there any other ideas?
Here is the IOMUX configuration I used (DDR_INPUT = 1 == differential)
// SDQS0..7
MXC_DCD_ITEM(2, IOMUXC_BASE_ADDR + 0x5a8, 0x00023038)
MXC_DCD_ITEM(3, IOMUXC_BASE_ADDR + 0x5b0, 0x00023038)
MXC_DCD_ITEM(4, IOMUXC_BASE_ADDR + 0x524, 0x00023038)
MXC_DCD_ITEM(5, IOMUXC_BASE_ADDR + 0x51c, 0x00023038)
MXC_DCD_ITEM(6, IOMUXC_BASE_ADDR + 0x518, 0x00023038)
MXC_DCD_ITEM(7, IOMUXC_BASE_ADDR + 0x50c, 0x00023038)
MXC_DCD_ITEM(8, IOMUXC_BASE_ADDR + 0x5b8, 0x00023038)
MXC_DCD_ITEM(9, IOMUXC_BASE_ADDR + 0x5c0, 0x00023038)
// DQM0..7
MXC_DCD_ITEM(10, IOMUXC_BASE_ADDR + 0x5ac, 0x00020038)
MXC_DCD_ITEM(11, IOMUXC_BASE_ADDR + 0x5b4, 0x00020038)
MXC_DCD_ITEM(12, IOMUXC_BASE_ADDR + 0x528, 0x00020038)
MXC_DCD_ITEM(13, IOMUXC_BASE_ADDR + 0x520, 0x00020038)
MXC_DCD_ITEM(14, IOMUXC_BASE_ADDR + 0x514, 0x00020038)
MXC_DCD_ITEM(15, IOMUXC_BASE_ADDR + 0x510, 0x00020038)
MXC_DCD_ITEM(16, IOMUXC_BASE_ADDR + 0x5bc, 0x00020038)
MXC_DCD_ITEM(17, IOMUXC_BASE_ADDR + 0x5c4, 0x00020038)
// CAS
MXC_DCD_ITEM(18, IOMUXC_BASE_ADDR + 0x56c, 0x00020038)
// RAS
MXC_DCD_ITEM(19, IOMUXC_BASE_ADDR + 0x578, 0x00020038)
// SDCLK_0
MXC_DCD_ITEM(20, IOMUXC_BASE_ADDR + 0x588, 0x00020038)
// SDCLK_1
MXC_DCD_ITEM(21, IOMUXC_BASE_ADDR + 0x594, 0x00020038)
// RESET
MXC_DCD_ITEM(22, IOMUXC_BASE_ADDR + 0x57c, 0x00020038)
// SDCKE0
MXC_DCD_ITEM(23, IOMUXC_BASE_ADDR + 0x590, 0x00020038)
// SDCKE1
MXC_DCD_ITEM(24, IOMUXC_BASE_ADDR + 0x598, 0x00020038)
// SDBA2
// SDODT0
MXC_DCD_ITEM(26, IOMUXC_BASE_ADDR + 0x59c, 0x00020038)
// SDODT1
MXC_DCD_ITEM(27, IOMUXC_BASE_ADDR + 0x5a0, 0x00020038)
// GRP_B0..7DS
// GRP_ADDDS
// GRP_DDRMODE_CTL
// GRP_DDRPKE
// GRP_DDRMODE
// GRP_CTLDS
// GRP_DDR_TYPE
Thanks!
Ofer
11,647 次查看
AnsonHuang
Hi, Ofer
     Sorry that I am not MMDC expert, I do NOT have any idea of adjusting these MMDC settings, you may need to involve MMDC expert to help.
11,647 次查看
rp123
Hi Yamil,
Have you been able to get this to work?
If so may you share your flash_hease.S file?
11,647 次查看
weidong_sun
Hello,Yamil,
      I just tell you the way on how to do that ! you should adjust it according to your board. for setting your memory , you need to refer to 2 files:
(1) u-boot/board/freescale/mx6q_sabresd/flash_header.S(I assume you are refering to mx6q-sabresd board)
All configurations of memory controller are in this file. According to note in it, you can know what we should do.
(2)Registers for memory controller
you should look up the meaning of every register bit that is used in flash_header.S in reference manual(IMX6DQRM.pdf), Then adjust the value of corresponding registers. Normally, the following contents should be modified:
** Row address lines
** Column address lines
** data lines
** Resistence
** the type of DDR (DDR2,DDR3 or LPDDR2 etc)
If you take some time on it, you can do it well.
Weidong
