How to enable MJPEG encoding with i.mx6 VPU and Linux mainline kernel
1,686 次查看
bogens
Hi all,
we're using a i.MX6q together with a Linux mainline kernel and the CODA kernel module, which works quite well to encode Video with a gstreamer chain
The question is now, how could we enable the mjpeg encoding feature of the VPU in this setup?
标签 (3)
1,600 次查看
bogens
Hi Bio_TICFSL,
unfortunately there is no vpudec gstreamer element available. Is this related to the gstreamer-imx ? As far as I know the gstreamer-imx elememts require the NXP kernel and they are not compatible to the mainline kernel. Beside this I need the VPU support for encoding.
Do you know if there is a mainline kernel compatible gstreamer element available which uses the VPU for mjpeg encoding?
Thanks in advance
1,600 次查看
Bio_TICFSL
Hello M B,
Try using vpudec, which is a hardware decoder:
gst-launch v4l2src ! vpudec ! mfw_v4lsink
