i.MX8Mnano EVK Altium designer files
rafb
I have to design a new board based on the i.MX8M nano.
We have Altium as CAD software.
Would it be possible to have the 8M nano/8M mini EVK schematic/layout in Altium format?
Thank you very much.
Raphael
Rita_Wang
Hi Raphael,
Unfortunately, we don't provide design file with Altium designer, Because our design tools is Allegro designer.
For i.mx8mm-evk, it's design files can't be converted, because it's design files are based on Allegro 17.2, whose version is too high, Altium designer doesn't support the conversion.
[Comment]Customer can also convert it by herself like steps below.
In Altium designer:
File-->Import Wizard-->next
you will see "Select Type of Files to Import" dialog. For example
Allegro Design Files  (For converting Allegro PCB to AD format)
OrCAD and PADs Designers and libraries Files   ( For schematic with .DSN)
Hope this can do help for you.
Have a nice day
Best Regards
Rita
