How to dump camera data on i.MX8
1,464件の閲覧回数
xu_ji1
hello,
How to dump camera raw data  that not pass through ISI to verify pure camera data correct or not on i.MX8?
3 返答(返信)
1,382件の閲覧回数
joanxie
do you need to check the raw data from camera? if yes, you should dump the memory which store the camera data
1,382件の閲覧回数
xu_ji1
It is yes,I try to dump memory after V4L2 dequeue operation,does it the pure camera data not pass through i.MX8 ISI?
1,382件の閲覧回数
joanxie
you can send the camera data to memory, then read the raw data from memory,don't dump memory after v4l2
