How to dump camera data on i.MX8
1,453 次查看
xu_ji1
hello,
How to dump camera raw data  that not pass through ISI to verify pure camera data correct or not on i.MX8?
1,371 次查看
joanxie
do you need to check the raw data from camera? if yes, you should dump the memory which store the camera data
1,371 次查看
xu_ji1
It is yes,I try to dump memory after V4L2 dequeue operation,does it the pure camera data not pass through i.MX8 ISI?
1,371 次查看
joanxie
you can send the camera data to memory, then read the raw data from memory,don't dump memory after v4l2
