How to disable automatic display power management
2,226 次查看
Huazhi_Hank_Gon
Hi guys,
I'm testing media playing on QSB with my own BSP. It's all working but my TV will lose the signal after a few minutes. I guess it's due to the power management setting in Linux. Does anyone know how to disable this feature?
Hank
标记 (2)
2,141 次查看
YinzheLu1
Fresh Out Contributor
Hi Hank!
I think you can disable setting through the graphic user interface by going under System -> Preference -> Power management. The menu for system is located on the top left corner of the screen for me.
2,141 次查看
Huazhi_Hank_Gon
Hi, Thank you! It worked...
2,141 次查看
BrilliantovKiri
Senior Contributor I
