How to cross compile an gstreamer application for Yocto Dunfell 5.4.85 kernel
4,025 次查看
KaviyaDharshini
We are trying to build a gstreamer application against aarch64-fslc-linux (Yocto dunfell 5.4.85). While building the gstreamer application we are facing this below error,
No package 'gstreamer-1.0' found
Package gstreamer-app-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gstreamer-app-1.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'gstreamer-app-1.0' found
Package gstreamer-video-1.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gstreamer-video-1.0.pc' to the PKG_CONFIG_PATH environment variable
No package 'gstreamer-video-1.0' found
In file included from feature_test.c:32:
inc_header.h:57:10: fatal error: gst/gst.h: No such file or directory
   57 | #include <gst/gst.h>
Can you please let us know how to build the gstreamer application for Dunfell Kernel version (5.4.85)?
Thanks in advance,
Kaviya  Dharshini
4,014 次查看
joanxie
what are your building steps?
4,006 次查看
KaviyaDharshini
We are using the following steps to build the application,
  1. source /opt/fslc-xwayland/3.1/environment-setup-aarch64-fslc-linux
  2. make
Our Makefile is,
SYSROOT:=/home/user/var-fslc-yocto/build_xwayland/tmp/work/aarch64-mx8m-fslc-linux/gstreamer1.0-plugins-ugly/1.16.3-r0/recipe-sysroot
CROSS_COMPILE:=aarch64-fslc-linux-
GCC:=gcc
PKG_CONFIG_PATH=${SYSROOT}/usr/lib/pkgconfig/
LDFLAGS:=`PKG_CONFIG_SYSROOT_DIR=${SYSROOT} PKG_CONFIG_PATH=${SYSROOT}/usr/lib/pkgconfig/ pkg-config --cflags --libs gstreamer-1.0 gstreamer-app-1.0 gstreamer-video-1.0`
INC_PATH= -I. -I./include
#LDFLAGS= -fPIE -pie
HEADER_FILE= ./file1.h ./file2.h ./file3.h
app.elf: file2.o file3.o
$(CROSS_COMPILE)$(GCC) --sysroot=${SYSROOT} $(INC_PATH) $(LDFLAGS) file2.o file3.o -lpthread -o app.elf
file2.o:file2.c $(HEADER_FILE)
$(CROSS_COMPILE)$(GCC) --sysroot=${SYSROOT} $(INC_PATH) $(LDFLAGS) file2.c -c -o file2.o
file3.o:file3.c $(HEADER_FILE)
$(CROSS_COMPILE)$(GCC) --sysroot=${SYSROOT} $(INC_PATH) $(LDFLAGS) file3.c -c -o file3.o
clean:
rm -rf *.elf *.o tags
Please let me know if you need any more information.
3,968 次查看
joanxie
I don't know what source code you download, you can refer to the chapter 2 of enclosed file, which includes cross compiler steps
