How to create patch file
5,882 次查看
hankwang
HI,
      I have finished modify code in the folder(/tmp/work-shared/imx6ulevk/kerner-source). Add device tree and
      configuration. Now i want to create path file put in my folder (source/meta-XXXX/recipes-kernel). How could i to do?
      thanks.
5,820 次查看
gusarambula
Hello Hank Wang,
There are a couple of ways to do this. You could create an append recipe (.bbappend) to your recipes to add the changes. You can find more regarding this on the Yocto Project Reference Manual:
https://www.yoctoproject.org/docs/latest/ref-manual/ref-manual.html#ref-classes-patch
If you already have a patch file you can use the do_patch function of bitbake. There is also information on the Yocto Projecr Manual.
I hope this helps!
5,821 次查看
gusarambula
Hello Hank Wang,
I hope this helps!
