About LCD1_DATA pin for BOOT_CFG setting
已解决
跳至解决方案
705 次查看
goto11
hello,Community
Pins not used for the purpose of the Boot function
Can I connect directly to GND without a pull-down resistor?
best regards
Goto
标签 (1)
1 解答
620 次查看
gusarambula
Hello Goto,
It’s recommended that you connect to ground using a resistor to limit current drain.
I hope this helps!
在原帖中查看解决方案
1 回复
621 次查看
gusarambula
Hello Goto,
I hope this helps!
