if you need to use AEC, AF, you need to use vvext tool, for example
In the Command Prompt window, type:
export LD_LIBRARY_PATH=$pwd:$LD_LIBRARY_PATH
./vvext <video_id>
where <video_id> specifies the video device number in the /dev folder (e.g., video1, video2, …, video 9).
The following menu should appear in the Command Prompt window.
