How to choose the version of Qt
6,604件の閲覧回数
jingyangxie
Sometimes,the default version of Qt in  yocto Project cannot meet our need,for example,in imx-4.1.15-1.0.0_ga,the default version is Qt5.5.1,but I want  to use Qt5.6, So can we specify the version of Qt in yocto Project according to our need?
ラベル(6)
5,087件の閲覧回数
JunZhu
look at the meta-qt5 community --  GitHub - meta-qt5/meta-qt5: QT5 layer for openembedded
The krogoth branch seems supports QT5.6.
Replace sources/meta-qt5 with the new version to build QT5.6
4 返答(返信)
5,087件の閲覧回数
jingyangxie
Can anyone knows?
5,088件の閲覧回数
JunZhu
5,088件の閲覧回数
jingyangxie
Hi,Jun Zhu,when I download the zip from GitHub - meta-qt5/meta-qt5: QT5 layer for openembedded,I replaced source /meta-qt5,but when I used bitbake fsl-image-qt5,it reported the error :
fsl-release-bsp/sources/meta-qt5/classes/qmake5_base.bbclass:50: cound not inherit file classes/remove-libtool.bbclass
Can you tell me how to solve this problem?
5,087件の閲覧回数
jingyangxie
thanks for answering my question,but I'm not familiar to yocto,can you list some steps to replace sources/meta/qt5 with the new version to build qt5.6?
