How to boot Linux directly from UUU
1,533件の閲覧回数
Ryo_Aoki
Hi community.
I am currently using an i.MX6 SabreAI board.
I want to boot linux directly from serial downloader mode without writing to emmc or QSPI or SD card.
Is such usage possible?
I have already checked the following documents, but I do not understand the procedure.
whether it can be used in such a way
If possible, could you please tell me the command procedure?
 UUU (Universal Update Utility)Document (uuu.pdf)
 https://github.com/nxp-imx/mfgtools
 LF5.15.71.2.2.0のLinuxUserGuide
1,519件の閲覧回数
joanxie
2 返答(返信)
1,520件の閲覧回数
joanxie
i.mx6 can boot up from usb, you can refer to the old community link
"https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Booting-Linux-through-USB-on-the-i-MX6-s..."
1,444件の閲覧回数
Ryo_Aoki
thank you for your reply. I will check the docs and give it a try.
