Hi Daiane, I must thank you for remembering me my thread.
Here I am posting the solution to that thread.
make directory in /mnt/YOUR_MOUNT_POINT for example
Then use this command.
mount -t vfat -o iocharset=utf8,umask=0022 /dev/mmcblk0p2 /mnt/YOUR_MOUNT_POINT
If its a ntfs/ext2/3/4, then the specific iocharset/ can be used
for ntfs
# sudo mount -t ntfs -o nls=utf8,umask=0222 /dev/hdb1 /media/c
umask can be obtained from the command in the help commands in terminal.
/dev/hdb1 is your device that can be obtained from "fdisk -l devicename" or "cat /proc/partitions"
we will get an iocharset error, but can be ignored if we are not using it on windows.
Regards :: Krishna Pavan
