How to Program NOR Flash with JTAG
3,124 次查看
samarora
Hi everyone,
I want to know how to program NOR Flash with JTAG.
4 回复数
2,678 次查看
sinanakman
Senior Contributor III
Hi Sam
If you are referring to programming NOR flash on an
iMX based board via JTAG, you would need a JTAG
probe with flash programming capabilities.
I am using BDI3000 JTAG debugger and I am able to
program NOR flash on iMX based boards. If you
need more info on BDI3000, please let me know.
Sinan Akman
2,678 次查看
samarora
thanks Sinan,
could u tell me more about BDI3000 JTAG . i want to install RT Linux on NOR Flash so please tell me how can i do this.
2,678 次查看
sinanakman
Hi Sam
Here is the manual for BDI3000 that has more info :
http://www.abatron.ch/fileadmin/user_upload/products/pdf/ManGDBA11-3000.pdf
If you have a custom board you will need to modify the config
file accordingly.
Hope this helps
Sinan Akman
2,678 次查看
igorpadykov
Hi Sam
programming NOR Flash with JTAG is not supported on i.MX
processors.
