How to Program NOR Flash with JTAG
3,109件の閲覧回数
samarora
Hi everyone,
I want to know how to program NOR Flash with JTAG.
4 返答(返信)
2,663件の閲覧回数
sinanakman
Senior Contributor III
Hi Sam
If you are referring to programming NOR flash on an
iMX based board via JTAG, you would need a JTAG
probe with flash programming capabilities.
I am using BDI3000 JTAG debugger and I am able to
program NOR flash on iMX based boards. If you
need more info on BDI3000, please let me know.
Sinan Akman
2,663件の閲覧回数
samarora
thanks Sinan,
could u tell me more about BDI3000 JTAG . i want to install RT Linux on NOR Flash so please tell me how can i do this.
2,663件の閲覧回数
sinanakman
Hi Sam
Here is the manual for BDI3000 that has more info :
http://www.abatron.ch/fileadmin/user_upload/products/pdf/ManGDBA11-3000.pdf
If you have a custom board you will need to modify the config
file accordingly.
Hope this helps
Sinan Akman
2,663件の閲覧回数
Hi Sam
programming NOR Flash with JTAG is not supported on i.MX
processors.
