How gst send rtp stream on imx6qp yocto2.1
1,090 次查看
advten
I read the  linux_user's_guide.pdf,  but it only  introduced the gst receive RTP stream. Like this
$GSTL udpsrc do-timestamp=false uri=udp://10.192.241.255:10000 caps="application/x-rtp"
! rtpmp2tdepay ! aiurdemux streaming_latency=400 name=d d.
! queue ! vpudec ! queue ! overlaysink sync=true d. ! queue ! beepdec
! pulsesink sync=true
How used gst to send rtp stream on imx6qp. ? The system is yocto2.1
标记 (5)
987 次查看
joanxie
do you want to communicate udp between two boards? I tested with pc sending udp, if you need communicate between two boards. you can refer to the topic as below:
https://community.nxp.com/message/629872?commentID=629872#comment-629872
