How do I implement multithreading on ARM i.MX6 running Linux?
2,757 次查看
rhana
  Just a simple question, if anyone could point me to resources on this. It doesn't look like OpenMP supports ARM i.MX6.
What would you suggest?
Thank you.
标签 (3)
2,453 次查看
jamesbone
Actually, OpenMP is a set of API for customer's application program. If customer uses it to program and run on i.mx6 / bsp, It is no problem.
2,454 次查看
jamesbone
2,453 次查看
rhana
Thanks.
