Hi, i can't use acm. If i use acm if i switch adb on/off system not run.
Mu init.usb.rc
# Copyright 2013 The Android Open Source Project
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
on init
write /sys/class/android_usb/android0/f_rndis/manufacturer Freescale
write /sys/class/android_usb/android0/f_rndis/vendorID 18D1
write /sys/class/android_usb/android0/f_rndis/wceis 1
mount configfs none /config
mkdir /config/usb_gadget/g1
write /config/usb_gadget/g1/idVendor 0x18d1
write /config/usb_gadget/g1/idProduct 0x4e42
mkdir /config/usb_gadget/g1/strings/0x409
write /config/usb_gadget/g1/strings/0x409/serialnumber 0123459876
write /config/usb_gadget/g1/strings/0x409/manufacturer test
write /config/usb_gadget/g1/strings/0x409/product nv1
mkdir /config/usb_gadget/g1/configs/c.1
mkdir /config/usb_gadget/g1/configs/c.1/strings/0x409
write /config/usb_gadget/g1/configs/c.1/strings/0x409/configuration "cdc 2xACM+ECM"
mkdir /config/usb_gadget/g1/functions/acm.GS0
mkdir /config/usb_gadget/g1/functions/acm.GS1
mkdir /config/usb_gadget/g1/functions/acm.usb0
# ln -s /config/usb_gadget/g1/functions/acm.GS0 /config/usb_gadget/g1/configs/c.1
# ln -s /config/usb_gadget/g1/functions/acm.GS1 /config/usb_gadget/g1/configs/c.1
# ln -s /config/usb_gadget/g1/functions/ecm.usb0 /config/usb_gadget/g1/configs/c.1
on boot
write /sys/class/android_usb/android0/iSerial $ro.serialno
write /sys/class/android_usb/android0/iManufacturer $ro.product.manufacturer
write /sys/class/android_usb/android0/iProduct $ro.product.model
on fs
mkdir /dev/usb-ffs 0770 shell shell
mkdir /dev/usb-ffs/adb 0770 shell shell
mount functionfs adb /dev/usb-ffs/adb uid=2000,gid=2000
write /sys/class/android_usb/android0/f_ffs/aliases adb
# USB rndis configuration
on property:sys.usb.config=rndis
stop adbd
write /sys/class/android_usb/android0/enable 0
write /sys/class/android_usb/android0/idVendor 18d1
write /sys/class/android_usb/android0/idProduct 4e23
write /sys/class/android_usb/android0/functions ${sys.usb.config}
write /sys/class/android_usb/android0/bDeviceClass 224
write /sys/class/android_usb/android0/enable 1
setprop sys.usb.state ${sys.usb.config}
on property:sys.usb.config=mtp
stop adbd
write /sys/class/android_usb/android0/idProduct 4e41
write /sys/class/android_usb/android0/f_acm/instances 2
on property:sys.usb.config=mtp,acm
stop adbd
write /sys/class/android_usb/android0/idProduct 2513
on property:sys.usb.config=mtp,adb
stop adb
write /sys/class/android_usb/android0/idProduct 4e42
start adbd
write /config/usb_gadget/g1/UDC ci_hdrc.0
on property:sys.usb.config=mtp,acm,adb
write /sys/class/android_usb/android0/idProduct 2514
start adbd
on property:sys.usb.config=ptp
stop adbd
write /sys/class/android_usb/android0/idProduct 4e43
on property:sys.usb.config=ptp,adb
write /sys/class/android_usb/android0/idProduct 4e44
start adbd
How can i use acm and adb ?
