Hi gusarakbula,
I have install toolchain. I'm entering kernel folder as below:
~/fsl/build/tmp/work/imx6qsabresd-poky-linux-gnueabi/linux-imx/3.14.28-r0/git
However, we type make to compile kernel, the system will show some configuration as below:
How should we choose these?
Note: bitbake to compile no this situation.
neo@neo-P45VA:~/fsl/build/tmp/work/imx6qsabresd-poky-linux-gnueabi/linux-imx/3.14.28-r0/git$ make
scripts/kconfig/conf --silentoldconfig Kconfig
* Restart config...
* Linux/x86 3.14.28 Kernel Configuration
64-bit kernel (64BIT) [Y/n/?] (NEW)
* General setup
Cross-compiler tool prefix (CROSS_COMPILE) []
Compile also drivers which will not load (COMPILE_TEST) [N/y/?] n
Local version - append to kernel release (LOCALVERSION) [-1.0.0_ga] -1.0.0_ga
Automatically append version information to the version string (LOCALVERSION_AUTO) [Y/n/?] y
Kernel compression mode
1. Gzip (KERNEL_GZIP)
2. Bzip2 (KERNEL_BZIP2) (NEW)
3. LZMA (KERNEL_LZMA)
4. XZ (KERNEL_XZ)
> 5. LZO (KERNEL_LZO)
6. LZ4 (KERNEL_LZ4)
choice[1-6?]: 1
Default hostname (DEFAULT_HOSTNAME) [(none)] (none)
Support for paging of anonymous memory (swap) (SWAP) [Y/n/?] y
System V IPC (SYSVIPC) [Y/n/?] y
POSIX Message Queues (POSIX_MQUEUE) [N/y/?] n
open by fhandle syscalls (FHANDLE) [N/y/?] n
Auditing support (AUDIT) [N/y/?] n
Kernel .config support (IKCONFIG) [N/m/y/?] n
Kernel log buffer size (16 => 64KB, 17 => 128KB) (LOG_BUF_SHIFT) [18] 18
Checkpoint/restore support (CHECKPOINT_RESTORE) [N/y/?] n
Automatic process group scheduling (SCHED_AUTOGROUP) [N/y/?] n
Enable deprecated sysfs features to support old userspace tools (SYSFS_DEPRECATED) [N/y/?] n
Kernel->user space relay support (formerly relayfs) (RELAY) [Y/n/?] y
Initial RAM filesystem and RAM disk (initramfs/initrd) support (BLK_DEV_INITRD) [Y/n/?] y
Initramfs source file(s) (INITRAMFS_SOURCE) []
Support initial ramdisks compressed using gzip (RD_GZIP) [Y/n/?] y
Support initial ramdisks compressed using bzip2 (RD_BZIP2) [N/y/?] n
Support initial ramdisks compressed using LZMA (RD_LZMA) [N/y/?] n
Support initial ramdisks compressed using XZ (RD_XZ) [N/y/?] n
Support initial ramdisks compressed using LZO (RD_LZO) [N/y/?] n
Support initial ramdisks compressed using LZ4 (RD_LZ4) [N/y/?] n
Optimize for size (CC_OPTIMIZE_FOR_SIZE) [N/y/?] n
* Configure standard kernel features (expert users)
Configure standard kernel features (expert users) (EXPERT) [Y/n/?] y
Sysctl syscall support (SYSCTL_SYSCALL) [N/y/?] n
Load all symbols for debugging/ksymoops (KALLSYMS) [Y/n/?] y
Include all symbols in kallsyms (KALLSYMS_ALL) [Y/n/?] y
Enable support for printk (PRINTK) [Y/n/?] y
BUG() support (BUG) [Y/n/?] y
Enable ELF core dumps (ELF_CORE) [Y/n/?] y
Enable PC-Speaker support (PCSPKR_PLATFORM) [Y/n/?] (NEW)
Enable full-sized data structures for core (BASE_FULL) [Y/n/?] y
Enable futex support (FUTEX) [Y/n/?] y
Enable eventpoll support (EPOLL) [Y/n/?] y
Enable signalfd() system call (SIGNALFD) [Y/n/?] y
Enable timerfd() system call (TIMERFD) [Y/n/?] y
Enable eventfd() system call (EVENTFD) [Y/n/?] y
Use full shmem filesystem (SHMEM) [Y/n/?] y
Enable AIO support (AIO) [Y/n/?] y
Embedded system (EMBEDDED) [N/y/?] n
Enable VM event counters for /proc/vmstat (VM_EVENT_COUNTERS) [Y/n/?] y
Enable SLUB debugging support (SLUB_DEBUG) [N/y/?] n
Disable heap randomization (COMPAT_BRK) [N/y/?] n
Choose SLAB allocator
1. SLAB (SLAB)
> 2. SLUB (Unqueued Allocator) (SLUB)
3. SLOB (Simple Allocator) (SLOB)
choice[1-3?]: 2
SLUB per cpu partial cache (SLUB_CPU_PARTIAL) [Y/n/?] y
Provide system-wide ring of trusted keys (SYSTEM_TRUSTED_KEYRING) [N/y/?] n
Profiling support (PROFILING) [N/y/?] n
Kprobes (KPROBES) [N/y/?] n
Optimize very unlikely/likely branches (JUMP_LABEL) [N/y/?] n
Stack Protector buffer overflow detection
> 1. None (CC_STACKPROTECTOR_NONE)
2. Regular (CC_STACKPROTECTOR_REGULAR)
3. Strong (CC_STACKPROTECTOR_STRONG)
choice[1-3?]: 1
* Processor type and features
DMA memory allocation support (ZONE_DMA) [Y/n/?] y
Symmetric multi-processing support (SMP) [Y/n/?] y
Support for extended (non-PC) x86 platforms (X86_EXTENDED_PLATFORM) [Y/n/?] (NEW)
Single-depth WCHAN output (SCHED_OMIT_FRAME_POINTER) [Y/n/?] (NEW)
* Linux guest support
Linux guest support (HYPERVISOR_GUEST) [N/y/?] (NEW)
Memtest (MEMTEST) [N/y/?] (NEW)
Processor family
1. Opteron/Athlon64/Hammer/K8 (MK8) (NEW)
2. Intel P4 / older Netburst based Xeon (MPSC) (NEW)
3. Core 2/newer Xeon (MCORE2) (NEW)
4. Intel Atom (MATOM) (NEW)
> 5. Generic-x86-64 (GENERIC_CPU) (NEW)
