How can I include the .dtb in my .wic
950 次查看
Blake001
Hi, I revised the dts, generate a patch and revised my custom layer, it finally produce a test.dtb under the images directory, however, the test.dtb is not included in my wic file, how can I make the test.dtb in the wic file so that I can flash it to emmc easily?
928 次查看
Chavira
Hi @Blake001!
Thank you for contacting NXP Support!
Do you add the proper dtb to the configuration of the machine?
You can see and ezample in the link below:
https://github.com/nxp-imx/meta-imx/blob/91cd813d1c77ae37823ebafee27cd062cc829be0/meta-imx-bsp/conf/...
Best Regards!
Chavira
885 次查看
Blake001
Thank you very much! I tried you solution and it worked!
