Questions about the Yocto Project customization guide
1,370 次查看
Blake001
Hi Aldo,
I learned the customization guide here: https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Yocto-Project-customization-guide/ta-p/1...
It is very useful, I have one question regarding this:
$ bitbake imx-image-multimedia
#All the images built should appear at  <build directory>/tmp/deploy/images/<machine>
Will the images in the .wic? I changed a .dts and generated a .dtb but it is not in the wic, why?
All the best,
Blake
标签 (1)
标记 (1)
2 回复数
1,341 次查看
Chavira
Hi @Blake001!
Thank you for contacting NXP Support!
Do you add the proper dtb to the configuration of the machine?
You can see and ezample in the link below:
https://github.com/nxp-imx/meta-imx/blob/91cd813d1c77ae37823ebafee27cd062cc829be0/meta-imx-bsp/conf/...
Best Regards!
Chavira
1,285 次查看
Blake001
Thank you very much! Your solution works!
标记 (1)
