How can I get pre-written image of MIMXRT595EVK?
1,116 次查看
tomi3
I am using MIMXRT595EVK and G1120BOMIPI display.
While working and trying some examples, I'm getting confused whether EVK work well or not.
So, I want to return EVK to the original state, how can I get pre-written image (e.g. blinky) of MIMXRT595EVK?
Any help would be appreciated.
Thank you.
1,095 次查看
tomi3
Problem with not being able to write to EVK was solved.
Sorry for my misunderstanding isp mode config. (2-1-0 / 0-1-2)
1,108 次查看
tomi3
The current situation is like as follows.
Error in final launch sequence:
Failed to execute MI command:
-target-download
Error message from debugger back end:
Error finishing flash operation
-target-download
1,096 次查看
tomi3
