How To Reduce The Boot Time.
3,507 次查看
nandishguruling
Hi All ,
   please any one can have look about this issue till now its not solved https://community.nxp.com/thread/459641 your help is needed,
Thanks in advance.
Best Regards.
Nandish SG
4 回复数
2,902 次查看
fabio_estevam
2,902 次查看
nandishguruling
Hello Fabio,
Thanks for your quick reply, But in the above link information is insufficient for me, in my previous post i asked this question, should i change the image or what ?, my board is imx6dl sabreauto and image is fsl-image-qt5, But in Falcon mode how to do information is not clear to me, if you know how to do please share it here,
Nandish SG
2,902 次查看
gusarambula
Hello Nandish SG,
There is limited information regarding improving booting time as it does depend a lot on your particular implementation.
On the later part of the original thread community user Jeremy Sherrill recommended NitroBoot, which is a form of hibernation that allows the system too boot much faster. You can find more information regarding NitroBoot on the following link:
https://www.datalight.com/products/fast-boot-linux/
I hope this information helps!
2,902 次查看
nandishguruling
Hello Gusarambula,
Thanks for your quick reply, i want to just reduce the boot time and i want to see the display very soon within a few seconds, my image is "fsl-image-qt5" and board is imx6dl sabreauto, i tried all these inks
https://imxdev.gitlab.io/tutorial/How_to_decrease_boot_time_on_iMX6/
https://imxdev.gitlab.io/video/tutorial/Booting-iMX6-under-one-second/  but info is not clear to me. if you know how to do please share it here. Thanks in advance,
Nandish SG
