Hi how I get the camera application on Android on the Sabre SD
marcelballmann
Hi I cant find the camera application on the Android system. Im using the Sabre SD? I want to use the OV5642. What have I to do? I have read the Android Advanced Use Guide item 3. and how can I modify that myandroid/device/fsl/imx6/sabresd/init.rc file? Where is that file and how I can get access to that file.
Thank you
