Hi All, scripts and menuconfig
已解决
跳至解决方案
3,536 次查看
dariuszzawisko
I am building Yocto on the custom board with imx28. I use the imx28evk machine as my base.
I have created the custom layer with kernel modifications and my custom images.
What should I do to setup all starting scripts for different runlevels or simply to add some new starting scripts or export environment variables?
Should I patch the initscripts package or maybe there is another way to do that?
Do we have in Yocto something similar to the configuration menu in LTIB (./ltib -c)?
If we talk about the configuration menu I know about bitbake -c menuconfig linux-imx and bitbake -c menuconfig busybox.
Do we have more similar menus in Yocto (for imx28)?
Best Regards
Darek
标签 (3)
标记 (3)
1 解答
3,136 次查看
alejandrolozan1
The menuconfig use will depend on the package. In this case busybox, linux kernel feature menuconfig.
But most of them lack of menuconfig.
/Alejandro
在原帖中查看解决方案
3 回复数
3,136 次查看
alejandrolozan1
Do you mean that bitbake -c menuconfig linux-imx does not work for the imx28?
I have tested it and it works at least for the linux kernel.
Alejandro
3,136 次查看
dariuszzawisko
The command bitbake -c menuconfig linux-imx works very well and it allows change the kernel configuration.
I wondered if there are more configuration menus with gui.
3,136 次查看
alejandrolozan1
/Alejandro
