HDMI PATTERN TEST
HDMI PATTERN TEST
753 次查看
deepakraj
For iMX-93, we like to test HDMI using pattern test, Could you please command to test HDMI with color pattern
724 次查看
JorgeCas
If you need to test HDMI output with a color pattern test, you could try to use modetest utility from the libdrm-tests package.
Best regards.
