GUIX SDK Example not Working
vipuljain91
I am working on EVKB- 1052, I have taken example from SDK named " EVKB-IMXRT1050-guix_washing_machine". I successfully build it on IAR. when I download it on board, I am getting hard fault in touch thread.
Pavel_Hernandez
Hello, I review the example in the MCUXpresso IDE, and it is working as expected, I do not know if your issue is about the LCD, you may need a review if your Display is compatible. Pavel_Hernandez_1-1678315833495.png
I recommend downloading the MCUXpresso for the new RT devices.
Pavel
vipuljain91
I have checked the Display setting in display_support.h.
I am working with IAR IDE wchich is my requirement.
Still I am facing the same issue
Pavel_Hernandez
Hello, could you send me a picture of your setup?
Pavel
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you. Let my doing the test to the example, and I will share my results.
Pavel
