Flashing NAND using i.mx6ull over Serial UART
1,931 次查看
srishan
Dear I.MX Community,
In my custom design we dont have USB or SD card,  but I need to flash the images using UART to NAND flash, Atleast I want to falsh the U-boot to NAND flash and then later over the network and NFS and flash the other images like dtb, zimage and rootfs
Could you please share the NXP procedure over for flashing the U-boot to NAND flash using UART
Kindly do the needful as early as possible, as I am stuck with this from past many days
Many Thanks in advance
Eagerly awaiting for your replies
标签 (2)
1 回复
1,638 次查看
CarlosCasillas
You could take a look at the links below regarding complementary information about implementation of UART serial downloader for i.MX processors:
https://www.nxp.com/docs/en/application-note/AN3996.pdf
https://community.nxp.com/docs/DOC-1639
https://github.com/boundarydevices/imx_usb_loader
Hope this will be useful for you.
Best regards!
/Carlos
