Flash DSP Examples On iMX8ULP_EVK9
1,226 次查看
dhruvinrajpura
Hello
I am using IMX8ULP_EVK9 in that I am able to run basic led blink example by generating flash.bin with help of https://www.nxp.com/document/guide/getting-started-with-the-i-mx-8ulp-evk:GS-I.MX-8ULP-EVK?section=m...
But when I try to flash any dsp example(i.e dsp_pdm_sai_m33) with same step I am uable to upload it.
What will be step to flash dsp example in IMX8ULP_EVK, and how we can generate flash.bin file for dsp example, Is that the same way as all other example or some different way?
1,210 次查看
JorgeCas
I suggest you take a look on i.MX Linux User's Guide, specifically on chapter 4.7.4 Running the Arm Cortex-M4/7/33 image and this post.
There is also an application note related to remoteproc but does not include i.MX8ULP examples, maybe could be helpful.
Best regards.
