We were trying to get our driver up with wpa_supplicant BSD interface. The following is the error that we are facing when we issue a make:
make: *** No rule to make target `out/target/product/evk_6sl/obj/STATIC_LIBRARIES/lib_driver_cmd_rtl_intermediates/export_includes', needed by `out/target/product/evk_6sl/obj/EXECUTABLES/rtl_wpa_supplicant_intermediates/import_includes'. Stop.
make: *** Waiting for unfinished jobs....
We are unsure what may have gone wrong. The following are the changes made by us:
a) In wpa_supplicant/.config file we enabled CONFIG_DRIVER_BSD=y
Apart from this, the following are the changes made by us in the BoardConfig.mk file:
BOARD_WPA_SUPPLICANT_DRIVER := BSD
BOARD_HOSTAPD_DRIVER := BSD
The below remains the same:
| BOARD_HOSTAPD_PRIVATE_LIB_QCOM | := lib_driver_cmd_qcwcn |
| BOARD_WPA_SUPPLICANT_PRIVATE_LIB_QCOM | := lib_driver_cmd_qcwcn |
| BOARD_HOSTAPD_PRIVATE_LIB_RTL | := lib_driver_cmd_rtl |
| BOARD_WPA_SUPPLICANT_PRIVATE_LIB_RTL | := lib_driver_cmd_rtl |
Can someone help us as to what may have gone wrong?
