#FRDM-IMX93 #YOCTO
#FRDM-IMX93 #YOCTO
yejx
I recently purchased an FRDM iMX93 development board. I followed the instructions at https://www.nxp.com/document/guide/getting-started-with-frdm-imx93:GS-FRDM-IMX93?_gl=1*zkk08q*_ga* MTUyMTQ0MDk5NS4xNzgwNTY1MTg4*_ga_WM5LE0KMSH*czE3ODA2Mzk2ODgkbzQkZzEkdDE3ODA2NDAzMDgkajQwJGwwJGg1MzYwMjA4MTc.&section=build-and-run
When following the tutorial and running the command “$ bitbake imx-image-full”, the following error appears. How can I resolve this?
Thank you!
ERROR: linux-imx-headers-6.6-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/998/bus"; export PATH="/home/yejx/imx93/frdm-imx93/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/yejx/imx93/sources/poky/scripts:/home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/recipe-sysroot-native/usr/bin/aarch64-poky-linux:/home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/recipe-sysroot/usr/bin/crossscripts:/home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/recipe-sysroot-native/usr/sbin:/home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/recipe-sysroot-native/usr/bin:/home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/recipe-sysroot-native/sbin:/home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/recipe-sysroot-native/bin:/home/yejx/imx93/sources/poky/bitbake/bin:/home/yejx/imx93/frdm-imx93/tmp/hosttools"; export HOME="/home/yejx"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all clone --bare --mirror https://github.com/nxp-imx/linux-imx.git /home/yejx/imx93/downloads//git2/github.com.nxp-imx.linux-imx.git --progress failed with exit code 128, see logfile for output
ERROR: linux-imx-headers-6.6-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/nxp-imx/linux-imx.git;protocol=https;branch=lf-6.6.y')
ERROR: Logfile of failure stored in: /home/yejx/imx93/frdm-imx93/tmp/work/armv8a-mx93-poky-linux/linux-imx-headers/6.6/temp/log.do_fetch.2202373
ERROR: Task (/home/yejx/imx93/sources/meta-imx/meta-imx-bsp/recipes-kernel/linux/linux-imx-headers_6.6.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3099 tasks of which 1313 didn't need to be rerun and 9 failed.
Summary: 9 tasks failed:
/home/yejx/imx93/sources/meta-imx/meta-imx-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.24.0.imx.bb:do_fetch
/home/yejx/imx93/sources/meta-imx/meta-imx-ml/recipes-nnstreamer/nnstreamer/nnstreamer_2.2.0.bb:do_fetch
virtual:native:/home/yejx/imx93/sources/meta-imx/meta-imx-ml/recipes-libraries/tensorflow-lite/tensorflow-lite-host-tools_2.16.2.bb:do_fetch
/home/yejx/imx93/sources/meta-imx/meta-imx-bsp/recipes-multimedia/gstreamer/gstreamer1.0-plugins-bad_1.24.0.imx.bb:do_fetch
/home/yejx/imx93/sources/meta-freescale-distro/recipes-graphics/imx-gpu-sdk/libxdg-shell.bb:do_fetch
/home/yejx/imx93/sources/meta-imx/meta-imx-bsp/recipes-kernel/linux/linux-imx_6.6.bb:do_fetch
/home/yejx/imx93/sources/meta-imx/meta-imx-bsp/recipes-bsp/imx-atf/imx-atf_2.10.bb:do_fetch
/home/yejx/imx93/sources/meta-imx/meta-imx-bsp/recipes-bsp/imx-secure-enclave/imx-secure-enclave_git.bb:do_fetch
Summary: There were 30 WARNING messages.
Summary: There were 18 ERROR messages, returning a non-zero exit code.
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Bitbake do_fetch errors can be related to network and proxy configurations on every host and fetch tools.
1. Install host packages from 3.2 Host packages
2. Confirm Proxy and firewall blocking configuration, look for TLS/SSL issues as well,
3. Review https://medium.com/@pitchaimuthu321/common-yocto-build-failures-and-how-to-fix-them-embedded-bsp-deb...
Try again with:
$ bitbake -c cleansstate imx-image-full
%3CLINGO-SUB%20id%3D%22lingo-sub-2377363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%23FRDM-IMX93%20%23YOCTO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2377363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20recently%20purchased%20an%20FRDM%20iMX93%20development%20board.%20I%20followed%20the%20instructions%20at%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-imx93%3AGS-FRDM-IMX93%3F_gl%3D1*zkk08q*_ga*%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-imx93%3AGS-FRDM-IMX93%3F_gl%3D1*zkk08q*_ga*%3C%2FA%3E%20MTUyMTQ0MDk5NS4xNzgwNTY1MTg4*_ga_WM5LE0KMSH*czE3ODA2Mzk2ODgkbzQkZzEkdDE3ODA2NDAzMDgkajQwJGwwJGg1MzYwMjA4MTc.%26amp%3Bsection%3Dbuild-and-run%3C%2FP%3E%3CP%3EWhen%20following%20the%20tutorial%20and%20running%20the%20command%20%E2%80%9C%24%20bitbake%20imx-image-full%E2%80%9D%2C%20the%20following%20error%20appears.%20How%20can%20I%20resolve%20this%3F%3C%2FP%3E%3CP%3EThank%20you%EF%BC%81%3C%2FP%3E%3CP%3EERROR%3A%20linux-imx-headers-6.6-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Fetch%20command%20export%20PSEUDO_DISABLED%3D1%3B%20export%20DBUS_SESSION_BUS_ADDRESS%3D%22unix%3Apath%3D%2Frun%2Fuser%2F998%2Fbus%22%3B%20export%20PATH%3D%22%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fsysroots-uninative%2Fx86_64-linux%2Fusr%2Fbin%3A%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fpoky%2Fscripts%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Frecipe-sysroot-native%2Fusr%2Fbin%2Faarch64-poky-linux%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Frecipe-sysroot%2Fusr%2Fbin%2Fcrossscripts%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Frecipe-sysroot-native%2Fusr%2Fsbin%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Frecipe-sysroot-native%2Fusr%2Fbin%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Frecipe-sysroot-native%2Fsbin%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Frecipe-sysroot-native%2Fbin%3A%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fpoky%2Fbitbake%2Fbin%3A%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fhosttools%22%3B%20export%20HOME%3D%22%2Fhome%2Fyejx%22%3B%20LANG%3DC%20git%20-c%20gc.autoDetach%3Dfalse%20-c%20core.pager%3Dcat%20-c%20safe.bareRepository%3Dall%20clone%20--bare%20--mirror%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx.git%3C%2FA%3E%20%2Fhome%2Fyejx%2Fimx93%2Fdownloads%2F%2Fgit2%2Fgithub.com.nxp-imx.linux-imx.git%20--progress%20failed%20with%20exit%20code%20128%2C%20see%20logfile%20for%20output%3CBR%20%2F%3EERROR%3A%20linux-imx-headers-6.6-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx.git%3Bprotocol%3Dhttps%3Bbranch%3Dlf-6.6.y')%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fyejx%2Fimx93%2Ffrdm-imx93%2Ftmp%2Fwork%2Farmv8a-mx93-poky-linux%2Flinux-imx-headers%2F6.6%2Ftemp%2Flog.do_fetch.2202373%3CBR%20%2F%3EERROR%3A%20Task%20(%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-kernel%2Flinux%2Flinux-imx-headers_6.6.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%203099%20tasks%20of%20which%201313%20didn't%20need%20to%20be%20rerun%20and%209%20failed.%3C%2FP%3E%3CP%3ESummary%3A%209%20tasks%20failed%3A%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-plugins-base_1.24.0.imx.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2Frecipes-nnstreamer%2Fnnstreamer%2Fnnstreamer_2.2.0.bb%3Ado_fetch%3CBR%20%2F%3Evirtual%3Anative%3A%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2Frecipes-libraries%2Ftensorflow-lite%2Ftensorflow-lite-host-tools_2.16.2.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-plugins-bad_1.24.0.imx.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-freescale-distro%2Frecipes-graphics%2Fimx-gpu-sdk%2Flibxdg-shell.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-kernel%2Flinux%2Flinux-imx_6.6.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-bsp%2Fimx-atf%2Fimx-atf_2.10.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-bsp%2Fimx-secure-enclave%2Fimx-secure-enclave_git.bb%3Ado_fetch%3CBR%20%2F%3E%2Fhome%2Fyejx%2Fimx93%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-kernel%2Flinux%2Flinux-imx-headers_6.6.bb%3Ado_fetch%3CBR%20%2F%3ESummary%3A%20There%20were%2030%20WARNING%20messages.%3CBR%20%2F%3ESummary%3A%20There%20were%2018%20ERROR%20messages%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2377721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%23FRDM-IMX93%20%23YOCTO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2377721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20interest%20in%20NXP%20Semiconductor%20products%2C%3C%2FP%3E%0A%3CP%3EBitbake%20do_fetch%20errors%20can%20be%20related%20to%20network%20and%20proxy%20configurations%20on%20every%20host%20and%20fetch%20tools.%3C%2FP%3E%0A%3CP%3E1.%20Install%20host%20packages%20from%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10164.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.2%20Host%20packages%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E2.%20Confirm%20Proxy%20and%20firewall%20blocking%20configuration%2C%20look%20for%26nbsp%3BTLS%2FSSL%20issues%20as%20well%2C%3C%2FP%3E%0A%3CP%3E3.%20Review%20%3CA%20href%3D%22https%3A%2F%2Fmedium.com%2F%40pitchaimuthu321%2Fcommon-yocto-build-failures-and-how-to-fix-them-embedded-bsp-debugging-guide-fcd20e133add%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmedium.com%2F%40pitchaimuthu321%2Fcommon-yocto-build-failures-and-how-to-fix-them-embedded-bsp-debugging-guide-fcd20e133add%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ETry%20again%20with%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%24%20bitbake%20-c%20cleansstate%20imx-image-full%0A%24%20bitbake%20imx-image-full%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
