Error when trying to build u-boot through Yocto project
2,911 次查看
Ramprakash
Hi All,
I am trying to build u-boot from the yocto setup. I followed the steps mentioned in IMXLXYOCTOUG Rev. L5.4.70_2.3.0 — 31 December 2020 to setup the yocto project.
When i run the command  " $MACHINE=imx8qxpmek bitbake -c deploy u-boot-imx "
i get the following error "
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
MACHINE=imx8qxpmek is invalid. Please set a valid MACHINE in your local.conf, environment or other configuration file.
I am using a Ubuntu 16.04 machine. How to fix this issue?
Thanks and Regards,
Ramprakash
2,905 次查看
joanxie
refer to the yocto user guide, The recommended minimum Ubuntu version is 18.04 or later
2,893 次查看
Ramprakash
Hi @joanxie ,
Yes, I did go through the yocto guide and I saw ubuntu 16.04 LTS are one of the build system. Anyway I'll try again with Ubuntu 18.04 LTS.
Thanks and Regards,
Ramprakash
