ERROR: linux-libc-headers-5.10-r0 do_install: oe_runmake failed
CoreshR
system info:
Linux Version:Ubuntu 18.04
i.MX Linux Yocto Project BSP 5.4.70-2.3.6
BSP version : repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.70-2.3.6.xml
build command : DISTRO=fsl-imx-wayland MACHINE=imx8mqevk source imx-setup-release.sh -b bld-wayland
bitbake imx-image-multimedia
AND I GET :
Sstate summary: Wanted 1206 Local 0 Network 0 Missed 1206 Current 78 (0% match, 6% complete)
NOTE: Executing Tasks
ERROR: linux-libc-headers-5.10-r0 do_install: Execution of '/src/imx-yocto-bsp/bld-xwayland/tmp/work/cortexa53-crypto-poky-linux/linux-libc-headers/5.10-r0/temp/run.do_install.6770' failed with exit code 1:
HOSTCC scripts/basic/fixdep
cc1: fatal error: can't open '/tmp/cc6/stat.s' for writing: No such file or directory
compilation terminated.
scripts/Makefile.host:95: recipe for target 'scripts/basic/fixdep' failed
make[1]: *** [scripts/basic/fixdep] Error 1
Makefile:535: recipe for target 'scripts_basic' failed
make: *** [scripts_basic] Error 2
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /src/imx-yocto-bsp/bld-xwayland/tmp/work/cortexa53-crypto-poky-linux/linux-libc-headers/5.10-r0/temp/log.do_install.6770
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['virtual:native:/src/imx-yocto-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.7.5.bb:do_populate_sysroot', 'virtual:native:/src/imx-yocto-bsp/sources/poky/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', 'virtual:native:/src/imx-yocto-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.5.bb:do_populate_sysroot', 'virtual:native:/imx-yocto-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/src/imx-yocto-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.12.bb:do_populate_sysroot', 'virtual:native:/src/imx-yocto-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_populate_sysroot', 'virtual:native:/src/imx-yocto-bsp/sources/poky/meta/recipes-devtools/rsync/rsync_3.2.3.bb:do_populate_sysroot', '/src/imx-yocto-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['bison-native', 'patch-native', 'xz-native', 'pseudo-native', 'unifdef-native', 'pkgconfig-native', 'rsync-native', 'quilt-native', 'autoconf-native', 'libtool-native', 'automake-native', 'texinfo-dummy-native', 'gettext-minimal-native', 'flex-native', 'attr-native', 'popt-native', 'acl-native', 'gnu-config-native', 'm4-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| NOTE: make -j 8 HOSTCC=gcc HOSTCPP=gcc -E headers_install INSTALL_HDR_PATH=/src/imx-yocto-bsp/bld-xwayland/tmp/work/cortexa53-crypto-poky-linux/linux-libc-headers/5.10-r0/image/usr
| ERROR: oe_runmake failed
| ERROR: Execution of '/src/imx-yocto-bsp/bld-xwayland/tmp/work/cortexa53-crypto-poky-linux/linux-libc-headers/5.10-r0/temp/run.do_install.6770' failed with exit code 1:
ERROR: Task (/src/imx-yocto-bsp/sources/meta-imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_5.10.bb:do_install) failed with exit code '1'
Pseudo log:
Setup complete, sending SIGUSR1 to pid 6772.
path mismatch [1 link]: ino 20588255 db '/proc/6873/status' req '/proc/6965/status'.
path mismatch [1 link]: ino 20588255 db '/proc/6873/status' req '/proc/7093/status'.
path mismatch [1 link]: ino 20588255 db '/proc/6873/status' req '/proc/7203/status'.
path mismatch [1 link]: ino 20588255 db '/proc/6873/status' req '/proc/6762/stat'.
path mismatch [1 link]: ino 20588255 db '/proc/6873/status' req '/proc/7531/status'.
Waiting for 1 running tasks to finish:
NOTE: Tasks Summary: Attempted 370 tasks of which 359 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Labels (2)
Zhiming_Liu
Which BSP version you use?
CoreshR
i try few BSP version and in all i get the same error.
the last log was :    imx-5.4.70-2.3.6
and i try today : imx-5.4.3-1.0.0
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.3-1.0.0.xml
repo sync
please find the log of imx-5.4.3-1.0.0:
xxx@emb-:~/src/imx-linux-zeus$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.3-1.0.0.xml
remote: Enumerating objects: 15, done.
remote: Counting objects: 100% (13/13), done.
remote: Compressing objects: 100% (13/13), done.
remote: Total 15 (delta 3), reused 0 (delta 0), pack-reused 2
repo has been initialized in /src/imx-linux-zeus
xxx@emb-:~/src/imx-linux-zeus$ repo sync
remote: Enumerating objects: 7660, done.
remote: Counting objects: 100% (2872/2872), done.
remote: Compressing objects: 100% (279/279), done.
remote: Total 7660 (delta 2649), reused 2593 (delta 2592), pack-reused 4788
Receiving objects: 100% (7660/7660), 2.69 MiB | 8.36 MiB/s, done.
Resolving deltas: 100% (5031/5031), done.
Fetching projects: 9% (1/11) meta-browserremote: Enumerating objects: 281, done.
remote: Total 281 (delta 0), reused 0 (delta 0), pack-reused 281
Receiving objects: 100% (281/281), 67.07 KiB | 149.00 KiB/s, done.
Resolving deltas: 100% (151/151), done.
Fetching projects: 18% (2/11) fsl-community-bsp-baseremote: Enumerating objects: 7354, done.
remote: Counting objects: 100% (925/925), done.
remote: Compressing objects: 100% (376/376), done.
remote: Enumerating objects: 42172, done. .13 MiB/s s
remote: Counting objects: 100% (4495/4495), done. s
remote: Compressing objects: 100% (601/601), done.
remote: Total 7354 (delta 557), reused 826 (delta 526), pack-reused 6429
Receiving objects: 100% (7354/7354), 2.89 MiB | 1.27 MiB/s, done.
Resolving deltas: 100% (4336/4336), done.
remote: Enumerating objects: 2260, done. | 430.00 KiB/s bjects: 0% (321/42172), 172.00 KiB | 253.00 KiB/s
remote: Counting objects: 100% (351/351), done.
remote: Compressing objects: 100% (175/175), done.
remote: Total 2260 (delta 164), reused 304 (delta 151), pack-reused 1909
Receiving objects: 100% (2260/2260), 17.78 MiB | 4.61 MiB/s, done.
Resolving deltas: 100% (1196/1196), done.
Receiving objects: 100% (158102/158102), 14.93 MiB | 35.80 MiB/s, done. 6% (2531/42172), 1.90 MiB | 325.00 KiB/s
Resolving deltas: 100% (103740/103740), done.
remote: Enumerating objects: 64333, done. | 744.00 KiB/s
remote: Counting objects: 100% (51852/51852), done.
remote: Compressing objects: 100% (12303/12303), done.
remote: Total 64333 (delta 39989), reused 50244 (delta 38640), pack-reused 12481
Receiving objects: 100% (64333/64333), 5.94 MiB | 3.58 MiB/s, done.
Resolving deltas: 100% (49582/49582), completed with 233 local objects.
remote: Enumerating objects: 183140, done. 1.14 MiB/s 36206/42172), 14.46 MiB | 1.05 MiB/s
remote: Total 183140 (delta 0), reused 0 (delta 0), pack-reused 183140
Receiving objects: 100% (183140/183140), 54.13 MiB | 1.73 MiB/s, done.
Resolving deltas: 100% (108284/108284), done.MiB | 351.00 KiB/s
remote: Enumerating objects: 15332, done. eceiving objects: 86% (36290/42172), 30.68 MiB | 427.00 KiB/s
remote: Counting objects: 100% (1070/1070), done.
remote: Compressing objects: 100% (340/340), done.
remote: Total 15332 (delta 752), reused 967 (delta 717), pack-reused 14262
Receiving objects: 100% (15332/15332), 3.89 MiB | 1.30 MiB/s, done.
Resolving deltas: 100% (10833/10833), done.
remote: Enumerating objects: 5347, done. | 623.00 KiB/s 290/42172), 33.25 MiB | 614.00 KiB/s
remote: Counting objects: 100% (308/308), done.
remote: Compressing objects: 100% (179/179), done.
remote: Total 5347 (delta 140), reused 238 (delta 112), pack-reused 5039
Receiving objects: 100% (5347/5347), 1.14 MiB | 1.58 MiB/s, done.
Resolving deltas: 100% (2915/2915), done.
remote: Enumerating objects: 2619, done. g objects: 86% (36290/42172), 34.52 MiB | 561.00 KiB/s
remote: Total 2619 (delta 0), reused 0 (delta 0), pack-reused 2619
Receiving objects: 100% (2619/2619), 423.67 KiB | 1.64 MiB/s, done.
Resolving deltas: 100% (1335/1335), done.
remote: Enumerating objects: 559479, done. 472.00 KiB/s (36290/42172), 35.45 MiB | 488.00 KiB/s
remote: Counting objects: 100% (2197/2197), done.
remote: Compressing objects: 100% (837/837), done.
remote: Total 42172 (delta 4210), reused 3891 (delta 3891), pack-reused 37677
Receiving objects: 100% (42172/42172), 45.00 MiB | 475.00 KiB/s, done.
Resolving deltas: 100% (25202/25202), done.76 MiB | 773.00 KiB/s
remote: Total 559479 (delta 1660), reused 1611 (delta 1350), pack-reused 557282 9.09 MiB | 772.00 KiB/s Receiving objects: 100% (559479/559479), 182.21 MiB | 399.00 KiB/s, done.
Resolving deltas: 100% (405878/405878), done.
Fetching projects: 100% (11/11), done.
info: A new version of repo is available
warning: project 'repo' branch 'master' is not signed
warning: Skipped upgrade to unverified version
Checking out projects: 100% (11/11), done.
repo sync has finished successfully.
xxx@emb:/src/imx-linux-zeus$ DISTRO=fsl-imx-wayland MACHINE=imx8mqevk source imx-setup-release.sh -b bld-wayland
Build directory is bld-wayland
Welcome to Freescale Community BSP
The Yocto Project has extensive documentation about OE including a
reference manual which can be found at:
http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
http://www.openembedded.org/
You can now run 'bitbake <target>'
Common targets are:
core-image-minimal
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
Your configuration files at bld-wayland have not been touched.
BSPDIR=
BUILD_DIR=.
meta-freescale directory found
xxx@emb-://src/imx-linux-zeus/bld-wayland$
xxx@emb-:/src/imx-linux-zeus/bld-wayland$ bitbake imx-image-multimedia
NOTE: Your conf/bblayers.conf has been automatically updated.
Loading cache: 100% |########################################################################################################################| Time: 0:00:00
Loaded 4068 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.44.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-18.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mqevk"
DISTRO = "fsl-imx-wayland"
DISTRO_VERSION = "5.4-zeus"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta
meta-poky = "HEAD:0275e68b0576cdefc19718e4b1977044f9f43f48"
meta-oe
meta-multimedia
meta-python = "HEAD:aad5b3d070cd8c58828b0975cf861d8ebc90f460"
meta-freescale = "HEAD:0be39721cea6e04c589a419f4bb07fabd0da6704"
meta-freescale-3rdparty = "HEAD:aea3771baa77e74762358ceb673d407e36637e5f"
meta-freescale-distro = "HEAD:ca27d12e4964d1336e662bcc60184bbff526c857"
meta-bsp
meta-sdk
meta-ml = "HEAD:f227d2449291456e947786cb935276cd7ce72ca0"
meta-browser = "HEAD:5f365ef0f842ba4651efe88787cf9c63bc8b6cb3"
meta-rust = "HEAD:5cda04c7c2158fc982502ca1e7893f71e4ca1729"
meta-gnome
meta-networking
meta-filesystems = "HEAD:aad5b3d070cd8c58828b0975cf861d8ebc90f460"
meta-qt5 = "HEAD:432ad2aa6c3a13253fefc909faba368851d21fb1"
Initialising tasks: 100% |###################################################################################################################| Time: 0:00:03
Sstate summary: Wanted 2638 Found 0 Missed 2638 Current 6 (0% match, 0% complete)
NOTE: Setscene tasks completed
WARNING: icu-64.2-r0 do_fetch: Checksum mismatch for local file /src/imx-linux-zeus/downloads/icu4c-64_2-src.tgz
Cleaning and trying again.
WARNING: icu-64.2-r0 do_fetch: Renaming /src/imx-linux-zeus/downloads/icu4c-64_2-src.tgz to  /src/imx-linux-zeus/downloads/icu4c-64_2-src.tgz_bad-checksum_ae95a5d5990b8f03b3fe305930276b8d
WARNING: icu-64.2-r0 do_fetch: Checksum failure encountered with download of http://download.icu-project.org/files/icu4c/64.2/icu4c-64_2-src.tgz - will attempt other sources if available
WARNING: pango-1.44.6-r0 do_fetch: Failed to fetch URL https://ftp.gnome.org/pub/GNOME/sources/pango/1.44/pango-1.44.6.tar.xz;name=archive, attempting MIRRORS if available
WARNING: gdk-pixbuf-native-2.38.2-r0 do_fetch: Failed to fetch URL https://ftp.gnome.org/pub/GNOME/sources/gdk-pixbuf/2.38/gdk-pixbuf-2.38.2.tar.xz, attempting MIRRORS if available
WARNING: json-glib-1.4.4-r0 do_fetch: Failed to fetch URL https://ftp.gnome.org/pub/GNOME/sources/json-glib/1.4/json-glib-1.4.4.tar.xz;name=archive, attempting MIRRORS if available
ERROR: linux-libc-headers-5.4-r0 do_install: oe_runmake failed
ERROR: linux-libc-headers-5.4-r0 do_install: Execution of '/src/imx-linux-zeus/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/run.do_install.12374' failed with exit code 1:
cc1: fatal error: can't open '/tmp/cc0/stat.s' for writing: No such file or directory
scripts/Makefile.host:107: recipe for target 'scripts/basic/fixdep' failed
Makefile:500: recipe for target 'scripts_basic' failed
WARNING: /src/imx-linux-zeus/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/run.do_install.12374:1 exit 1 from 'exit 1'
ERROR: Logfile of failure stored in: /src/imx-linux-zeus/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/log.do_install.12374
Log data follows:
| NOTE: Direct dependencies are ['virtual:native:/src/imx-linux-zeus/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus/sources/poky/meta/recipes-devtools/bison/bison_3.4.1.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus/sources/poky/meta/recipes-extended/xz/xz_5.2.4.bb:do_populate_sysroot', '/src/imx-linux-zeus/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: ['pseudo-native']
| NOTE: Skipping as already exists in sysroot: ['bison-native', 'xz-native', 'quilt-native', 'unifdef-native', 'pkgconfig-native', 'autoconf-native', 'automake-native', 'gettext-minimal-native', 'libtool-native', 'gnu-config-native', 'flex-native', 'texinfo-dummy-native', 'm4-native']
| NOTE: make -j 12 HOSTCC=gcc HOSTCPP=gcc -E headers_install INSTALL_HDR_PATH=/src/imx-linux-zeus/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/image/usr
| ERROR: Execution of '/src/imx-linux-zeus/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/run.do_install.12374' failed with exit code 1:
ERROR: Task (/src/imx-linux-zeus/sources/meta-imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_5.4.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 571 tasks of which 343 didn't need to be rerun and 1 failed.ore
Zhiming_Liu
Try this command:
sudo apt-get install --reinstall build-essential
 You need install all host packages in Yocto user guide
CoreshR
i already follow all instruction on my host to meets the following requirements:
  • Git 1.8.3.1 or greater
  • tar 1.28 or greater
  • Python 3.5.0 or greater.
  • gcc 5.0 or greater.
my steps:
sudo apt update
sudo apt upgrade
//  sudo apt-get build-dep qemu
//  sudo apt-get remove oss4-dev
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat cpio python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev \
pylint3 xterm
sudo apt-get install build-essential
my version:
repo launcher version 2.21
(from /home/sdk/bin/repo)
git 2.17.1
Python 3.6.9 (default, Mar 15 2022, 13:55:28)
[GCC 8.4.0]
OS Linux 4.15.0-175-generic (#184-Ubuntu SMP Thu Mar 24 17:48:36 UTC 2022)
CPU x86_64 (x86_64)
xxx@linux:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.6 LTS
Release: 18.04
Codename: bionic
xxx@linux:~$ git --version
git version 2.17.1
xxx@linux:~$ tar --version
tar (GNU tar) 1.29
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
xxx@linux:~$ gcc --version
gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
xxx@linux:~$ python --version
Python 2.7.17
xxx@linux:~$ python3 --version
Python 3.6.9
i also set:
alias python=python3
i still failed on linux-libc-headers
last log :
repo init -u https://source.codeaurora.org/external/imx/imx-manifest.git -b imx-linux-zeus -m imx-5.4.70-2.3.6.xml
repo sync
xxx@linux:src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6$ DISTRO=fsl-imx-wayland MACHINE=imx8mpevk source imx-setup-release.sh -b bld-wayland
/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6
Common targets are:
core-image-minimal
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
BSPDIR=
BUILD_DIR=.
xxx@linux:src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/bld-wayland$ bitbake imx-image-multimedia
Loading cache: 100% |##############################################################################################################################################| Time: 0:00:00
Loaded 4652 entries from dependency cache.
Parsing recipes: 100% |############################################################################################################################################| Time: 0:00:03
Parsing of 3225 .bb files complete (3224 cached, 1 parsed). 4653 targets, 467 skipped, 3 masked, 0 errors.
MACHINE = "imx8mpevk"
TUNE_FEATURES = "aarch64 cortexa53 crc crypto"
TARGET_FPU = ""
meta
meta-poky = "HEAD:d88d62c20d7d8da85f02edb170dae0280624ad7e"
meta-oe
meta-multimedia
meta-python = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b"
meta-freescale = "HEAD:14f1a630a47375432f93c556927b879b51d84c4e"
meta-freescale-3rdparty = "HEAD:dbcc686f52c3c84db8cb86aa8973a4e373651b98"
meta-bsp
meta-sdk
meta-ml
meta-v2x = "HEAD:cb0780d07a4d3eda232432656a4377edd966b857"
meta-nxp-demo-experience = "HEAD:c7263d9f3cc7bbf44e7164ffeda494cf283d3dec"
meta-browser = "HEAD:ee3be3b5986a4aa0e73df2204a625ae1fe5df37e"
meta-rust = "HEAD:53bfa324891966a2daf5d36dc13d4a43725aebed"
meta-clang = "HEAD:711e593d5984aad3bf35c51b7ac4482982bc16c7"
meta-gnome
meta-networking
meta-filesystems = "HEAD:2b5dd1eb81cd08bc065bc76125f2856e9383e98b"
meta-qt5 = "HEAD:21ce4c124d9a972d9122f87c64ac2773bf04c284"
meta-python2 = "HEAD:4400f9155ec193d028208cf0c66aeed2ba2b00ab"
Initialising tasks: 100% |#########################################################################################################################################| Time: 0:00:03
Sstate summary: Wanted 2679 Found 0 Missed 2679 Current 32 (0% match, 1% complete)
ERROR: linux-libc-headers-5.4-r0 do_install: Execution of '/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/run.do_install.28617' failed with exit code 1:
cc1: fatal error: can't open '/tmp/cc3/stat.s' for writing: No such file or directory
ERROR: Logfile of failure stored in: /src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/log.do_install.28617
Log data follows:
| NOTE: Direct dependencies are ['virtual:native:src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_populate_sysroot', 'virtual:native:src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-extended/xz/xz_5.2.4.bb:do_populate_sysroot', '/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-devtools/bison/bison_3.4.1.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb:do_populate_sysroot', 'virtual:native:/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/poky/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot']
| NOTE: Skipping as already exists in sysroot: ['pkgconfig-native', 'pseudo-native', 'xz-native', 'quilt-native', 'bison-native', 'unifdef-native', 'patch-native', 'gnu-config-native', 'autoconf-native', 'libtool-native', 'automake-native', 'gettext-minimal-native', 'flex-native', 'texinfo-dummy-native', 'attr-native', 'm4-native']
| NOTE: make -j 8 HOSTCC=gcc HOSTCPP=gcc -E headers_install INSTALL_HDR_PATH=/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/image/usr
| ERROR: Execution of '/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/bld-wayland/tmp/work/aarch64-poky-linux/linux-libc-headers/5.4-r0/temp/run.do_install.28617' failed with exit code 1:
ERROR: Task (/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/sources/meta-imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_5.4.bb:do_install) failed with exit code '1'
Second Keyboard Interrupt, stopping...
xxx@linux:/src/imx-linux-zeus-BULD/imx1-5_4_70_2-3-6/bld-wayland$
