EIM correct wait cycles between CSs
888件の閲覧回数
norishinozaki
Contributor V
Hello Champs,
We would like to determine the correct wait cycles between 2 CSs in EIM.
We figured out following cycles from the i.MX21 reference manual.
However we are not sure if we have correct understanding.
Could you check if following values are correct not?
I. Regarding CNC
1. In CS[4], we set WSC=2, CNC=3, EDC=0, CSA=CSN=0
1-1. After a Read access to CS[4],
  a. A Read access to the same CS[4] delayed 3 HCLK cycles?
  b. A Read access to CS[2] delayed 3 HCLK cycles?
  c. A Write access to the same CS[4] 3 HCLK cycles?
  d. A Write access to CS[2] delayed 3 HCLK cycles?
1-2. After a Write access to CS[4],
2. In CS[4], we set WSC=4, CNC=3, EDC=0, CSA=1, CSN=0
2-1. After a Read access to CS[4],
  (The same questions as 1-1)
2-2. After a Write access to CS[4],
  a. A Read access to the same CS[4] delayed 0 HCLK cycles?
  b. A Read access to CS[2] delayed 0 HCLK cycles?
  c. A Write access to the same CS[4] 0 HCLK cycles?
  d. A Write access to CS[2] delayed 0 HCLK cycles?
3. In CS[4], we set WSC=4, CNC=3, EDC=0, CSA=0, CSN=1
3-1. After a Read access to CS[4],
3-2. After a Write access to CS[4],
  (The same questions as 2-2)
II. Regarding EDC
4. In CS[4], we set WSC=2, CNC=0, EDC=2, CSA=CSN=0
4-1. After a Read access to CS[4],
  a. A Read access to the same CS[4] delayed 0 HCLK cycle?
  b. A Read access to CS[2] delayed 2 HCLK cycles?
  c. A Write access to the same CS[4] 2 HCLK cycles?
  d. A Write access to CS[2] delayed 2 HCLK cycles?
4-2. After a Write access to CS[4],
III. Combination of CNC and EDC
5. In CS[4], we set WSC=2, CNC=3, EDC=2, CSA=CSN=0
5-1. After a Read access to CS[4],
  b. A Read access to CS[2] delayed 3+2 HCLK cycles?
  c. A Write access to the same CS[4] 3+2 HCLK cycles?
  d. A Write access to CS[2] delayed 3+2 HCLK cycles?
5-2. After a Write access to CS[4],
  (The same questions as 1-1?)
6. In CS[4], we set WSC=4, CNC=3, EDC=2, CSA=1, CSN=0
6-1. After a Read access to CS[4],
  (The same questions as 5-1?)
6-2. After a Write access to CS[4],
7. In CS[4], we set WSC=4, CNC=3, EDC=2, CSA=0, CSN=1
7-1. After a Read access to CS[4],
7-2. After a Write access to CS[4],
Nori Shinozaki
0 返答(返信)
