Hi 宗標 廖
V20 gpio1.31 can be used by linux and mfg tools as ENET_MDC signal.
Also gpio1.31 has NVCC_ENET power domain,
while pad U6 - NVCC_GPIO, G21 -NVCC_EIM0.
Probably ADC has incompatible voltage levels used by these i.MX6 pads.
In general one can use a GPIO as chip select for SPI slave.
You can check if ADC is fully powered when i.MX6 begin to boot from SPI and
that ADC should no be powered before i.MX6.
