Does the MFGtool requires the Serial Downloader Boot mode over IMX6
1,473件の閲覧回数
adityanagal
HI ,
I am working over IMX6 solo based target board . I learnt that , boot device can be programmed using MFGtool . My question is , to program using the MFGtool , does the boot configuration settings for the IMX6 solo need to be set to the Serial Downloader mode. Please conform.
Aditya Nagal
1,085件の閲覧回数
joanxie
for how to set board , you can refer to the linux user guide, which depends what device you use, mmc, sd card or nand flash, for more detailed information, pls refer to the chapter 4.5 How to boot the i.MX boards of enclosed file.
