Is the internal Boot ROM has functionality to write to the NAND?
Is the Boot ROM code opensourced, like AT91BootStrap from ATMEL?
Any links for OBDS? BTW, what it is?
 Karl Lu said:
Boot ROM just reads from NAND flash but doesn't write to. If you are looking for simple code for NAND read/write, OBDS is a good reference.
 VladanJovanovic
			VladanJovanovic
		Not sure if it has that functionality as such, but it's main point is to read bootloader/bootstream (depending on device you have in mind) from boot device.
Code is not open-sourced, but behavior is documented in reference manual.
