Hello
Are there any tricks to getting the PWM output (GPIO_1_PWM2_PWMO) to output anything other than zero volts other than
echo 100 > /sys/devices/platform/mxc_pwm.1/pwm-backlight.0/backlight/pwm-backlight.0/brightness
The value is being reflected in the actual_brightness file but I get no output from the PWM pin.
